Latest post Wed, Aug 27 2008 10:30 PM by Sycophant. 7 replies.
  • Wed, Aug 27 2008 8:16 AM
    Begin Capture from 00;00;00;00
    I have a DV tape that has useful material starting from the absolute very beginning. I've tried changing the starting timecode and Preroll Method settings, but I can't seem get capture to start at TC 00;00;00;00. The best I can get is starting two seconds in by setting Custom Preroll to 1 sec and the in point to 00;00;02;00.
    I'm using a Canon HV-20 as a deck with the Canon XL1 deck preset. The material is SD DV.
    Thanks very much!
    P.S. I've been trying to educate the filmer of this material on the importance of preroll and handles, but sometimes she regresses :(.
    P4 3.0. 2 Gig RAM, CAS 2.5. Intel 865PERL mobo. Two WD 7,200 IDE drives and two WD Raptor 10,000 SATA drives--no RAID. nVIDIA Quadro FX 1100. Two EIZO... [view my complete system specs]
  • Wed, Aug 27 2008 8:48 AM In reply to
    • yaronlvn
    • Joined on Thu, Jul 24 2008
    • Livnay
    • Posts 1
    • Points 15
    Re: Begin Capture from 00;00;00;00
    Hi.
    The only solution I know is to capture the first few seconds 'On-the-Fly'.
    Just place the deck on the very first frame, and hit the record button. It still wont capture from the first frame, but it is the best you can do keeping the original TC.
    If you want even more you can disable the TC track in the capture tool, and capture only the first 5-6 seconds. make sure to capture it in DV resolution an not in 15:1 so you don't have to re-capture for online.
    Avid Mediacomposer 3.0.1, Mojo, Mac pro dual 2.66, 3 gig ram, Sony DSR-11PAL [view my complete system specs]
  • Wed, Aug 27 2008 9:02 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 781
    • Points 9,605
    My advice is 'let it go' - unless you absolutely have to have it, just write of the first 5-seconds and capture from 00:00:05:00...
    If you really really need the first few seconds the best result I've had is to control the deck manually (still capturing timecode in Avid through). Rewind the tape to the head, position the mouse over the Record button in Avid, press play on the deck and click Record in Avid as soon as the timecode starts rolling in the Digitise Tool. This way I can normally get within the first second a tape.
    All manner of fancy edity stuff [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
  • Wed, Aug 27 2008 9:58 AM In reply to
    Unfortunately I do have to have it, the line is critical :(.
    What do you have the Preroll set to? Thanks!
  • Wed, Aug 27 2008 10:07 AM In reply to
    For the first shot. Turn off TC and Machine control. manually cue the tape to the first frame and pause it. Hit record on Avid then release pause on the deck. Avid should record the freeze frame and then the moving footage.  Should get you a clean record of all bar the first 5 frames or so whilst the deck gets uo to speed.
    As suggested above record at online resolution
  • Wed, Aug 27 2008 3:36 PM In reply to
     You could also crash dub the entire tape to another and offset the recording start time to allow for pre-roll.
    BobbyMurcerFan:
    Best way to remedy that is to stop using her - make her capture it or pay for the expense that you're having to endure during her "regression"
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Aug 27 2008 10:03 PM In reply to
    BobbyMurcerFan:
    Whatever happened to rolling 30 secs of Bars and Tone at the top of a tape. That little habit will fix this problem everytime.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Wed, Aug 27 2008 10:30 PM In reply to
    • Sycophant
    • Posts 781
    • Points 9,605
    mr_difficult:
    Or black, or a hand, or feet, or the camera case, or pretty much anything other than something important. Bars and tone are nice, but not so necessary in the days of digital... Just non-important stuff really.
