Latest post Sun, Sep 7 2008 3:25 PM by papu. 15 replies.
  • Tue, Aug 26 2008 9:10 PM
    • alforn
    • Joined on Tue, Aug 26 2008
    • Posts 6
    • Points 100
    Crying [:'(] Decrypt and move files from AVID MediaFiles folder?!
    I've done the enormous mistake to by accident move my project folder to my AVID MediaFiles folder and now I can't get a hold of it. I can open the AVID MediaFiles folder but that's it, can't move, copy or open anything in there. I've been trying to decrypt the AVID MediaFiles folder but that doesn't work. I've also tried to copy it and paste it on the desktop, doesn't work either. Has this happend to anyone before? Please help me! I'm desperate! I got over 2 years of work in that folder!
    I'm running my system on a windows Xp service pack 2. Intel Core 2 CPU 6600 @ 2.40 GHz 3.50 GB RAM and got AVID XPRESS PRO v. 5.8!
    Please tell me there's something I can do...
    Regards
    Alex
    Filed under: , ,
  • Tue, Aug 26 2008 9:54 PM In reply to
    Re: Decrypt and move files from AVID MediaFiles folder?!
    Backstop is researching Avids Attic Folder. In there you will find backups of most of your work.
    First you need to look at the permissions for your Avid MediaFiles folder. You should be able to dump the kitchen sink in there and wash the dishes before getting both the clean dishes and kitchen sink back out of that folder without problems.
  • Tue, Aug 26 2008 11:13 PM In reply to
    • alforn
    • Posts 6
    • Points 100
    The problem is that it's not only the project folder but it's the attic folder as well. I've looked at the permissions for my AVID MediaFolder and de-clicked the write protection box but it still doesn't work. I still get the same warning message; Access denied...
  • Wed, Aug 27 2008 12:19 AM In reply to
    What OS are you using?
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Aug 27 2008 12:24 AM In reply to
    • alforn
    • Posts 6
    • Points 100
    Windows XP Service pack 2
    INTEL Core 2 CPU
    6600 @ 2.40 GHZ
    2.40 GHZ, 3,50 GB RAM
  • Wed, Aug 27 2008 12:26 AM In reply to
    XPHome or Pro?
  • Wed, Aug 27 2008 7:36 AM In reply to
    And what if you right click on the folder.
    Select properties.
    Select security
    Select user
    Select full Control?
    If that does not do it. Select Advanced and edit  your permissions
  • Wed, Aug 27 2008 12:49 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,660
    • Points 78,890
    Kenton.VanNatten:
    XPHome or Pro?
    I am interested in that as well Smile
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Aug 27 2008 6:50 PM In reply to
    • alforn
    • Posts 6
    • Points 100
    AVID XPRESS PRO HD 5.8
  • Wed, Aug 27 2008 7:01 PM In reply to
    • alforn
    • Posts 6
    • Points 100
    AndrewAction:
    Select properties.
    Select security
    Select user
    I've tried that and it seems to work until I try to move it. Then it says acess denied again.
    Thanks for trying to help, I've been trying so many diffrent things but I can't figure it out.
  • Wed, Aug 27 2008 7:04 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,571
    • Points 78,520
     Here is a procedure regarding setting permissions.
  • Fri, Aug 29 2008 6:16 PM In reply to
    • Solopost
    • New Jersey
    • Posts 1,071
    • Points 12,225
    "AVID XPRESS PRO HD 5.8"
    Very nice... What OS (not service pack) - Windows XP PRO or HOME?
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Fri, Aug 29 2008 6:31 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,571
    • Points 78,520
     Windows XP Pro, SP 2, 32 bit
    {EDIT} Disregard
  • Mon, Sep 1 2008 10:56 PM In reply to
    • alforn
    • Posts 6
    • Points 100
    Solopost:
    Thank you so much for trying to help me out! I got Windows XP PRO. I've even tried to re-install both windows and Avid but it still doesn't work.
    Any ideas?
  • Tue, Sep 2 2008 3:53 PM In reply to
    • Baklap
    • Posts 6,660
    • Points 78,890
    You should read this post CLICK which Larry earlier posted very very very good. It is your problem looking from a rights point of view. If that all fails then i suggest you get someone out there with a little bit more computer knowledge (no offense!)
    Menno
    Dutch AV forum
