Latest post Mon, Aug 25 2008 8:13 PM by Kevin Sio. 2 replies.
  • Mon, Aug 25 2008 3:30 PM
    • Kevin Sio
    • Syracuse, NY
    • Posts 238
    • Points 2,940
    DVDit will not import an AC3?
    After upgrading to Media Composer 2.8 from Express a few months ago, I noticed that the provided DVD authoring software, DVDit, did not seem to be compatible with an AC3 audio file.  In my limited experience this audio file seems to be a bit of a standard...any body else having the problem?
    thanks
    Kevin
    HP-xw8600 Media Composer 2.8 [view my complete system specs]
  • Mon, Aug 25 2008 6:59 PM In reply to
    • Avid Technology Inc.
    • Posts 855
    • Points 11,380
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: DVDit will not import an AC3?
     Hi kevin,
    What version of DVDit are you using?  And when did you get it ( with Xpress or MC 2.8)?
    I know there is a standalone AC3 encoder but not sure if that affects your workflow.  Get me some version info and when you got it and I can check for you.
    BTW we now ship DVD by Sonic with MC systems.
    Let me know.
    marianna_montague@avid.com
    813-493-6800
    AOL IM avidmarianna
  • Mon, Aug 25 2008 8:13 PM In reply to
    • Kevin Sio
    • Syracuse, NY
    • Posts 238
    • Points 2,940
     Hi Marianna
    Thanks for looking into this for me.  I am using Media Composer 2.8.1.  When I upgraded from Xpress (back in April) I installed DVDit, it came with MC.  DVDit is 6.0  621B12B (not sure if those last numbers are important).  I suppose it is not a big deal to loose AC3 files, they were smaller than the .wav's I have to use now and that was nice on big projects.
    I do have MC 3 waiting in the wings and I'm just a little skittish about installing it.  I guess I should just suck it up and install it!
    Kevin
