Latest post Sun, Aug 24 2008 7:21 PM by kutter. 15 replies.
  • Sat, Aug 23 2008 8:48 PM
    • kutter
    • Joined on Sun, Jun 17 2007
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Help Please
    I could really use some help….
    Here’s my problem:
    I am on a g5, osx 10.4.11, 3gbs Ram using MCSoft 2.8.3. with a Mojo SDI. I am using a 1TB external 7200rpm Firewire drive. I have a Sony JH-3 deck.  I am trying to capture HDCam footage shot at 59.94. I made window-burns to DVD for the client, she logged them and then gave me her selects. I have tried hooking up the deck, Component, SDI and Composite, no video. Also, no audio. I have made a project at 59.94, I open the capture tool, I can select my audio-A1-A2, but the video says “No Inputs Available”. I made a project at 30i, I open the capture tool, I can select my audio-A1-A2, I CAN select V1 in whatever input I want but nothing captures. I get a message saying “No valid video signal in current video input”. I tried using internal sync. I connected the sync on the deck to the word clock connector and I continue to get the same messages. I don’t have a black burst. I have never used a JH-3 before, I am able to control it with my Keyspan. Are there settings in the deck that I need to set?
    Kent Kreiger
    Kreiger Post
    hp workstation xw8200, SP2, 4 gbs ram, 3.40ghz, Symphony Nitris 1.8.3, XP Pro, QT 7.3.1 MCSoft 3.0.1 Apple G5 dual 2.0 O. S. x 10.4.11 ... [view my complete system specs]
    Kent Kreiger
    ACI
    Kreiger Post - Metropolitan Post
    http://www.kreigerpost.com
  • Sat, Aug 23 2008 8:56 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,999
    • Points 107,100
      Moderator: Meridien
    Re: Help Please
     Kent:
    Since you don't mention it, have you gone into the deck configuration settings, created the proper channel and associated a deck template with it?
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Aug 23 2008 9:07 PM In reply to
    • kellyv
    • Posts 153
    • Points 1,665
    Re: Help Please
    sounds like deck config to me too.
    Suites: Two MC Nitris DX's with Mac 3.0GHz Quad-Core Intel and Fusion D8000 RAID 6TB storage. Mobile: Macbook Pro 2.0GHz 15" Leopard with MC and... [view my complete system specs]
    spot editor
  • Sat, Aug 23 2008 9:17 PM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: Help Please
    Sorry for the oversight,  I went to Deck configuration and selected the Soby JH-3. 3 second pre-roll. It was in the list.
    Kent
    Kent Kreiger
    ACI
  • Sat, Aug 23 2008 9:22 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,999
    • Points 107,100
      Moderator: Meridien
    Re: Help Please
      And can I take it that you've already checked all your cable connections in and out of the deck and the Avid and tried some cable swap outs?  And since your system specs don't list it, are you running a qualified graphics card?
  • Sat, Aug 23 2008 9:48 PM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: Help Please
    I have a ATI Radeon 9600. I did check all cables.
    I'm not trying to caputure HD. Since the original footage was shot at 59.94 I was told that I could caputure it
    into a 29.97 project, but I haven't been given that option in the Avid. I SHOULD (unless I'm mistaken) be able to bring the footage into my Avid via the Mojo SDI to do an offline and then go to an Avid that CAN do HD for the online.
    Kent
    Kent Kreiger
    ACI
  • Sat, Aug 23 2008 10:06 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,999
    • Points 107,100
      Moderator: Meridien
    Re: Help Please
     You are correct. You should be able to bring in 59.94 footage into a 29.97 project. I know you say you don't have signal, but do you have deck control, or do you get a "no deck" prompt in the capture tool? If you do have deck control, then at least we know the configuration is good.
  • Sat, Aug 23 2008 10:11 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,999
    • Points 107,100
      Moderator: Meridien
    Re: Help Please
      Oh, and while I can't find system requirements for 2.8.3 anywhere to confirm this, I don't believe the ATI Radeon card was supported.
  • Sat, Aug 23 2008 10:13 PM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: Help Please
    I do have deck control. How do I make a 29.97 project?  The only 29.97
    option I get is 720p 29.97 HDV and that didn't work. That's why I
    tried 59.94.
    Kent
    Kent Kreiger
    ACI
  • Sat, Aug 23 2008 10:22 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,999
    • Points 107,100
      Moderator: Meridien
    Re: Help Please
    If you're not getting an appropriate 29.97 option in the "format" tab of the new project window, you can create a 30i project and work in that with 59.97 material.
  • Sat, Aug 23 2008 10:27 PM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: Help Please
    When I originally got the system, I was running MCSOFT 2.6. I got purchased the system from a Avid certified reseller in Phoenix. I have had no problems with Beta or Digi-beta decks.
    Kent
    Kent Kreiger
    ACI
  • Sat, Aug 23 2008 10:30 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,999
    • Points 107,100
      Moderator: Meridien
    Re: Help Please
     OK then at this point, it seems to be pointing back to the deck itself. Have you confirmed video and audio output from the deck straight into a monitor?
  • Sat, Aug 23 2008 10:48 PM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: Help Please
    On the front of the deck it has 29.97. I have a 30i project. I am
    connected to the SD-SDI and not the HD-SDI.I have connected my Sony
    monitor directly to the deck and I can see video.
    Kent
    Kent Kreiger
    ACI
  • Sat, Aug 23 2008 11:24 PM In reply to
    Re: Help Please
    I think you need to spend some time in the Sony's menu. to make sure that that is setup correctly.
    With my HDCAM deck I can get as picture on a direct connection to a monitor with all sorts of wrong frame rates.  Getting that signal to another HDCAM deck or Avid in a format that either will record requires all the settings to be correct on both source and record.
    I do not have any experience with the JH 3 but from your posts I would suggest looking at the JH 3's downconvert to SD SDI setting first.
    Thanks for the continued dongle support
  • Sun, Aug 24 2008 2:07 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,826
    • Points 201,075
    Re: Help Please
     That deck has on output menu selection. Are you certain that it is set to the proper output?
