Latest post Thu, Aug 21 2008 10:12 PM by Laptopeditor. 9 replies.
Page 1 of 1 (10 items)
  • Thu, Aug 21 2008 3:19 PM
    • CoPARQ
    • Joined on Wed, Mar 8 2006
    • Wisconsin
    • Posts 63
    • Points 755
    Transcode:1080i (Upper Field First) to SD - does field order stay Upper?
    Hello:
    Experiencing interlacing issue in 1080i > m2v for DVD.
    When Avid transcodes ATSC HD Standard, Upper Field Footage to Standard DV (Avid 1:1, MXF 25, etc.) does the field order stay Upper?
    Thank you for your time.
    System 1: Hp xw8200, XP Pro SP2, nVidia QuadroFX 1400, 3.5G RAM, Media Composer v.2.6.6. Toolkit v5.2.4 Ciprico MediaVault U320 Scsi, Quicktime 7.1... [view my complete system specs]
    Colleen P.
  • Thu, Aug 21 2008 5:22 PM In reply to
    • CoPARQ
    • Wisconsin
    • Posts 63
    • Points 755
    Re: Transcode:1080i (Upper Field First) to SD - does field order stay Upper?
    Along the same line -
    1. Is it safe to say:
    - an AVID 1080i/59.95 project exports  HDV Mpeg Transport & Program streams with UPPER FIELD FIRST order?
    - a 1080i/59.95 project will also export out a QT REF with an UPPER FIELD FIRST order
    - any After Effects comps built with interlaced footage from an AVID 1080i project should be rendered with UPPER FIELD FIRST order & imported into MC with UPPER FIELD FIRST
    Colleen P.
  • Thu, Aug 21 2008 6:27 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    CoPARQ:
    Hello:
     ...Your difficulties maybe stemming from your Export Settings Dialogue Box. Do not use the Quicktime Reference DV Codec setting in your Export # 1 Settings list. Rather, use the Quicktime Reference setting only. When you go from an HD source down to SD, the QT DV Codec Reference will reprocess the source material as if it was from a DV SD resoultion source, which it is not. It will assume your source is lower field first, which it is not, thus creating the anomaly you are seeing. I have included a setting example of an export dialogue box out of MC for an SD DVD Onestep process, but it is the same box as if you are going out to Sorensen Squeeze or Avid DVD. See below.....
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5, but had to roll back to 3.0.0. Also added Avid Studio Toolkit 5.7 running on.....HP... [view my complete system specs]
  • Thu, Aug 21 2008 6:30 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,440
    CoPARQ:
    You are correct. HD is alway upper field first.
  • Thu, Aug 21 2008 7:44 PM In reply to
    • CoPARQ
    • Wisconsin
    • Posts 63
    • Points 755
    Thank you for your helpful response -
    Just to recap & clarify - When moving 1080i footage down the chain to SD DVD M2v -- you are telling me NOT to use the QT REF export in BOTH SD and 1080i projects because it is a DV codec that reprocesses footage to lower FF (It assumes all footage is DV SD)
    Some old posts (from '05, '06) mention a way to Force field dominance in QT REF. Is this still possible with MC v2.8. I can no longer link to the urls in those posts.
    Colleen P.
  • Thu, Aug 21 2008 8:17 PM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    CoPARQ:
     .....No, you accomplish the same result by setting your QT Reference setting in your export dialogue box setting # 1 to use Regular QT Reference, and MC will default to using the Upper Field First.
  • Thu, Aug 21 2008 8:30 PM In reply to
    • CoPARQ
    • Wisconsin
    • Posts 63
    • Points 755
    Bear with me - I'm exporting on my Avid so I can't get into look at the settings:
    "setting your QT Reference setting in your export dialogue box setting # 1"
    Is this the Regular Export dialogue box or the "Send to" export dialogue box?
    If regular Export dialogue-  "#1" means the the tab you designate the file type, correct?
    Thank you.
    Colleen P.
  • Thu, Aug 21 2008 8:49 PM In reply to
    • CoPARQ
    • Wisconsin
    • Posts 63
    • Points 755
    Yes - I see you mean in the "Send To" export dialog.
    Colleen P.
  • Thu, Aug 21 2008 8:52 PM In reply to
    • CoPARQ
    • Wisconsin
    • Posts 63
    • Points 755
    I am still wondering:
    When Avid transcodes ATSC HD Standard, Upper Field Footage to Standard DV (Avid 1:1, MXF 25, etc.) does the field order stay Upper? or is that an idiotic question because all DV is Lower FF?
    Colleen P.
  • Thu, Aug 21 2008 10:12 PM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    CoPARQ:
     ....Actually, the best way to explain this is to say that it translates it to the lower field first (B field), which is standard for all NTSC 720 x 480, 486, or 704 x 480 work.
