Latest post Thu, Aug 21 2008 6:23 PM by Larry Rubin. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Aug 18 2008 9:11 PM
    • ronjohn
    • Salt Lake City
    • Posts 60
    • Points 700
    Direct Output 4 channels
    I know I've done this before but maybe not with 10 bit video. I'm trying to output a sequence to DigiBeta with 4 discreet audio channels. When I try I get this error – Exception: ADVAudioDev: Audio underrun on DV device. My output to DV device setting is off. If I just output 2 channels it works fine. Add 3 and 4 and I get the error. In the meantime I'm laying the shows off twice. I'll just insert 3 & 4 on a second pass. Of course this is going to take me twice as long (I have 4 shows to do).
    MC 2.8.3
    Adrenaline HD, Mac G5 2.5 Quad, 4.5 Gig Ram, OSX 10.4.11, MCA 3.0.5, QT 7.4.5, rS73/320 LVD drives, Lacie FW800 drives, Huge SCSI Disk array. MC Soft... [view my complete system specs]
  • Mon, Aug 18 2008 9:53 PM In reply to
    • ronjohn
    • Salt Lake City
    • Posts 60
    • Points 700
    Re: Direct Output 4 channels
    Just an update, it appears that I cannot insert edit to tracks 3 & 4 without getting this error. Any combination with Video and audio 3 & 4 fails.
  • Mon, Aug 18 2008 10:32 PM In reply to
    • yale
    • Joined on Thu, May 15 2008
    • Fabulous HOLLYWOOD, CALIFORNIA!
    • Posts 104
    • Points 1,205
    Are you using SDI audio or AES/EBU?  Whichever one it is, try the other and see if it works.  You might be able to swap the 1/2 and 3/4 AES/EBU cables, but Avid's help guide seems to think that can lead to sync problems, at least on capture.
  • Mon, Aug 18 2008 11:09 PM In reply to
    • ronjohn
    • Salt Lake City
    • Posts 60
    • Points 700
    I've tried both SDI and AES/EBU. If I swap the cables I won't be able to insert on 3 & 4 with the correct channels. I just tried reloading at 1:1 mxf not 10 bit. Still no luck. I really thought 10 bit might have been the problem. Even stripping the video tracks and trying to record black with channels 3 & 4 doesn't work. I also loaded installed 2.8.4. I know I've done 4 channels direct out with video before but I don't know which version of software I was using when I did it.
  • Mon, Aug 18 2008 11:31 PM In reply to
    • yale
    • Posts 104
    • Points 1,205
    Here's a post that suggests rebuilding your media database.
  • Mon, Aug 18 2008 11:32 PM In reply to
    • yale
    • Posts 104
    • Points 1,205
    Sorry, stupid forum didn't display my last post for some reason...
  • Mon, Aug 18 2008 11:42 PM In reply to
    • ronjohn
    • Salt Lake City
    • Posts 60
    • Points 700
    I tried that too. Here's my work around - and it's a minute in and still working :) I switched my audio tracks on the time line so that 3 & 4 is on 1 & 2. Then switched my aes/ebu cables as suggested and then playing back 1 & 2 in the digital cut tool and inserting on 3 & 4. The problem only happens when doing direct out and selecting 3 & 4 on the source side of the digital cut tool. Still a bummer cause I have to lay off the shows twice, but better than not doing it at all...
  • Wed, Aug 20 2008 10:29 PM In reply to
    • ronjohn
    • Salt Lake City
    • Posts 60
    • Points 700
    Had to do another layback so I decided to open up a new project. That fixed the problem, maybe something was corrupt in the project file.
  • Wed, Aug 20 2008 10:33 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
    ronjohn:
     If you still have the problem project, you can delete the "(Project Name)settings.avs" file in that particular project folder. On re-launch, the system will detect the missing file and build a new one. Then see if you get channels 3 and 4 working. Just an experiment to test the theory.
  • Thu, Aug 21 2008 6:07 PM In reply to
    • ronjohn
    • Salt Lake City
    • Posts 60
    • Points 700
    Deleting the .avs file worked! Thanks Larry
  • Thu, Aug 21 2008 6:23 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     You're welcome, Ronjohn. Whenever you have a strange issue that's contained to only one project, it's usually because that project's settings file has become corrupted.
