Latest post Wed, Aug 20 2008 9:43 PM by mikewolf1127. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Aug 18 2008 6:50 PM
    • mikewolf1127
    • Venice, CA
    • Posts 26
    • Points 360
    Downconvert output different in Symphony...
    Just upgraded to SymphonyDX from AdrenalineHD.
    On the AdrenalineHD, Setting the Video Output Tool to Downconvert would output downconverted SD AND still output HD at the same time.
    The SymphonyDX seems to turn off the HD output when set to Downconvert in the Video Output Tool.  Am I missing something?
    Avid Symphony DX / Mac Pro 8 Core / OS 10.5.5 / 4 GB RAM / 3 TB Fibre Channel Storage / DVW-500 DigiBeta / Ocean Views / Great Snacks [view my complete system specs]
    Mike Wolf
    Wild Pictures
    Venice, CA
    www.wildpictures.com
    www.michaelwolfphotography.com
  • Mon, Aug 18 2008 7:10 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,871
    • Points 175,825
    Re: Downconvert output different in Symphony...
     Nope, that's the way it's working here too.
  • Mon, Aug 18 2008 8:39 PM In reply to
    • TCurren
    • Posts 1,088
    • Points 14,065
    There's still value in the classic Nitris.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
  • Mon, Aug 18 2008 11:10 PM In reply to
    • AvidHammer
    • Joined on Mon, Mar 13 2006
    • Los Angeles
    • Posts 114
    • Points 1,245
    TCurren:
    Interestingly enough, we've got someone running both DS 3.0 and DX 3.0.
    DS is on an 8400 (8 X 2.33 GHz), 3500, 4Gigs of RAM, 3GB batch file run.
    DX is on an 8600 (8 X 3.0 GHz), 3700, 4 Gigs RAM, 3GB batch file run.
    The DX (faster comp.) renders a short sequence in 7 minutes.
    The DS (slower comp.) renders the exact same sequence in 3:45 min.
    Codec Board/Base Board processing?  That's the only thing I can come up with.  But yeah, there's still value in the classic Nitris.
    ~Hammer
  • Wed, Aug 20 2008 9:26 PM In reply to
    What outputs are you using?  We can monitor HD through the HD-SDI out and SD downconvert -- through the analog component out -- simultaneously.
    Remember, Adrenaline had separate HD and SD component outs...the DX boxes only have one, so it has to switch depending on how you are using it.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Wed, Aug 20 2008 9:43 PM In reply to
    • mikewolf1127
    • Venice, CA
    • Posts 26
    • Points 360
    No, the SymphonyDX has 2 HD-SDI outs and 1 SD-SDI out.
    Here's the word from Avid-
    This is only true for 1080p/23.976. We won’t have full-quality simultaneous down-convert until DeMille-B releases.
    All other formats that support downconvert can be simultaneously output as in HD and SD.
    Mike Wolf
    Wild Pictures
    Venice, CA
