Latest post Wed, Aug 20 2008 5:52 AM by housemouse. 9 replies.
Page 1 of 1 (10 items)
  • Sat, Aug 16 2008 5:18 AM
    Bad Quality text in Avid FX & Composer
    I create text in Avid FX (5.8). Looks great in the FX monitor. When I apply it into Composer (3.0), it doesn't look good at all. Edges are rough and all the text actually is somewhat grainy.
    In FX..all setting are 'high', in Composer Video quality is high....it looks bad rendered or not. But render setting are set high.
    When I do text in the Title Tool, or Marquee, it looks like fine.
    I'm using a Sony monitor so this is not looking at the computer monitor.
    I have also tried various fonts and they all do it.
    I had been using Red before I udgraded to Composer and it was working ok.
    Any ideas?
    HP 8200
    Mojo
    Composer 3.0
    NVIDIA Quadra FX 1400
    2 gigs ram
    HP 8200/XP Pro, Mojo, Composer 3.0, NVIDIA Quadra FX 1400, 2 gigs ram, Avid FX, Sorenson 5, Adobe CS everything.... [view my complete system specs]
    Filed under: ,
  • Sat, Aug 16 2008 8:42 PM In reply to
    Re: Bad Quality text in Avid FX & Composer
    Confused
  • Sat, Aug 16 2008 8:45 PM In reply to
    • erik1185
    • Gaithersburg, MD
    • Posts 738
    • Points 9,200
    What does it look like when you export a quicktime file?
    Intel Core 2 Duo 3.0 GHZ, 2GB ram, Nvidia Quadro FX 570 [view my complete system specs]
  • Sat, Aug 16 2008 10:35 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 457
    • Points 5,395
    What resolution are you rendering to?  DV25 is pretty pixelated on the edges.  can you try 1:1 or even DV50?
    MC 3.0! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Sat, Aug 16 2008 10:58 PM In reply to
     It looks good on the computer monitor after exporting as a QT file.
    But looks bad in the Avid monitor, rendered or not...and bad on the Sony monitor...rendered or not.
    Thanks for the replies.
  • Sat, Aug 16 2008 11:44 PM In reply to
     it's not just the edges. the whole title has alot of what i could describe as video noise on it. But a title created in Marquee doesn't have it.
    OK, this is weird,  When I use and Avid FX preset, it looks ok. I can change the font color and add an outline, and include motion and it looks ok.
    When I click on 'Fonts' in the "Style Palette" window, there are no fonts listed there. There should be fonts there, I'd think.
    If I apply a 'style'...it makes the text look bad.
  • Mon, Aug 18 2008 8:47 PM In reply to
     just checking   Yes
  • Tue, Aug 19 2008 10:57 PM In reply to
     would this be better to post in the 'Studio' forum since it's part of that package?
  • Wed, Aug 20 2008 12:10 AM In reply to
    Possibly.... but 5.8 was not part of studio, I think 5.7 was the last there.
    I will run a quick test on 5.8 here at the end of today and see if I get the same problem. However I am in PAL so it may not be a valid comparison.
  • Wed, Aug 20 2008 5:52 AM In reply to
     thanks....i'm stumped on this one. tried everything i can think of.
