Latest post Wed, Aug 20 2008 3:09 AM by sean90291. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Aug 15 2008 11:28 PM
    • sean90291
    • Joined on Fri, Oct 21 2005
    • Toronto, Canada
    • Posts 252
    • Points 3,505
    Avid MC 16 bit effects versus After Effects 16 bit effects
     I see there is a 16-bit render option for effects in Avid. A lot of the same effect-suites are available for both Avid and After Effects. Is there any advantage in quality between Avid's 16-bit rendering and After Effects? I know AE has 32-bit. But most effects are limited to 16-bit anyhow. And I'm just wondering whether Avid's 16-bit renders truly give the same quality as AE's 16-bit renders.
    Red, shmed. This was shot with a cell phone: http://vimeo.com/1649221  Edited in Avid.
  • Sat, Aug 16 2008 5:47 AM In reply to
    Re: Avid MC 16 bit effects versus After Effects 16 bit effects
    Apples and oranges.
    AE is an FX app working in RGB up to 32 bit. Avid is an editing app working in YCrCb that has some function able to take advantage of 16 bit.
    Depending on your needs AE will likely produce better quality digital video. Staying in Avid likely will simplifies your workflow for TV and film editing projects.
  • Sat, Aug 16 2008 7:59 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,505
    • Points 40,510
    Dom Q. Silverio:
    Except that if you're exporting back to Avid, how would you know?  You convert from YUV to RGB going into AE, and from RGB to YUV going back again.  In practice the difference between either workflow is minimal.  The slight losses going to and from AE are usually well and truly outweighed by the power of the tools available there.
  • Mon, Aug 18 2008 4:44 AM In reply to
    • sean90291
    • Toronto, Canada
    • Posts 252
    • Points 3,505
     What I'm really trying to get at is whether the 16-bit rendering in Avid is any less effective than AE's 16-bit rendering. If you have the same plug-in for Avid as for AE (Sapphire for example), will Avid's 16-bit render be identical in quality to AE's render?
  • Mon, Aug 18 2008 6:13 AM In reply to
    • jwrl
    • Posts 3,505
    • Points 40,510
    Since that is dependant on how the plug-in is coded, who can say?  You really would have to do side-by-side objective tests of your planned workflow to have a definitive answer.  I suspect, though, that there wouldn't be any appreciable difference.
  • Mon, Aug 18 2008 12:25 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,526
    • Points 18,360
    sean90291:
     There may be a little difference in quality, but i doubt if someone can recognize it without microscop or is someone cares.
    The main thing to get good quality video is not to hunt a fraction of a better editing qualityh, the main price is the camera. A good camera with a good lens is paramount.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05 [view my complete system specs]
  • Mon, Aug 18 2008 2:03 PM In reply to
    • camoscato
    • Posts 4,696
    • Points 55,955
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    berga:
    Hahahahaha! Big Smile  Excellent point!
    adios,
    Carl
  • Mon, Aug 18 2008 4:47 PM In reply to
    • Haze
    • Posts 338
    • Points 4,580
    berga:
     Excellent point berga.  It makes little sense to split hairs over bit depth when the source material is 4:2:0.
  • Mon, Aug 18 2008 5:24 PM In reply to
    • Sasquatch
    • Nottingham England
    • Posts 526
    • Points 6,305
    Although I completely agree that quality aquisiton of video is important it doesn't really answer the question.
    Personally I would choose AE over MC everytime for a final effects sweep that is if you are outputting to another media which supports a high bit depth and don't have to go back into MC.
    However in less there was a specific need for the best quality I find effects rendered in MC good enough but it's more clumbersome.
    HPXW8400 4gb ram Nvidia FX 1500 MC 3 Adrenaline, HP XW8200 3gb ram Nvidia FX1400 MC 2.7 with SDI mojo, Avid express DV. [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Wed, Aug 20 2008 3:09 AM In reply to
    • sean90291
    • Toronto, Canada
    • Posts 252
    • Points 3,505
     Thanks Sasquatch.
    Interestingly Avid could push this in their promotion a bit more, since so many folks think that effects need to be done in AE for the best quality (even tho most AE effects are NOT 32 bit compatible).
    Still a bit unclear on whether Avid's color correction is rendering in 16-bit or not (while AE's basic color correction IS compatible with 32-bit projects...or you can render in 16-bit too).
