Latest post Wed, Aug 27 2008 3:06 PM by Joann. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Aug 15 2008 3:35 AM
    Does anyone who knows audio_play command in Macro of Deko Family?
    Recently, I have a project wants to trigge deko play audio. When I use macro command, "audio_play" which shows "Command audio_play not found". This command seem doesn't exist. But I read all versions of deko macro reference, all shows the command exist. What is going on? Is that a optional function? I'm using Deko 3000, Deko 1000, PostDEKO.
    audio_play
    Description: Play audio file
    Returns: integer: duration (msecs)
    Syntax
    [$integer=] audio_play name= [gain=]
    I also turn to found other solutions. I found some commands also as a mystry as follow:
    deko_objex_play_audio
    deko_objex_override_object_parameter
    deko_objex_get_object_parameter_value
    Those commands also won't work. (On Deko 3000)
    Is anyone who knows how to use those commands or have any sample.
    Thanks.
  • Wed, Aug 27 2008 3:06 PM In reply to
    • Joann
    • Joined on Wed, Aug 16 2006
    • Posts 67
    • Points 480
    Re: Does anyone who knows audio_play command in Macro of Deko Family?
     Hi Jerry,
    Audio is part of the ClipDeko option.  Deko Objex is also a separate option.  From your description, it sounds like your system is not enabled with these options.  You should contact your Avid sales rep/dealer for more info/pricing.
    Regards,
    Joann
