Latest post Fri, Aug 15 2008 6:40 AM by Laptopeditor. 18 replies.
Page 2 of 2 (19 items) < Previous 1 2
  • Thu, Aug 14 2008 6:57 PM In reply to
    • editzz01
    • Joined on Wed, Nov 23 2005
    • Montreal
    • Posts 734
    • Points 8,755
    Re: MC 3.0 Visual Effect Workflow Question for Episode 2: No Reflection
     I agree with the method of the green screen.
    Shoot clean plate locked downm.
    Then shoot actor coming in again locked down, but with green covering the mirror.
    Put the actor shot on V2, and the clean plate on V1, now apply the spectramatte to V2 and key out the green.....Seems to me that this would be much simpler, quicker and cleaner than trying to mask the actor by using the animatte.
    Make sure that the lighting is the same with both shots....also, keep the actor as far away from green as possible (cloths etc), as you will likely get some spill and do not want to start keying out parts of him.
    Regards
    Mark
    Dual 3.2 Xeon 2.0MB L2 Cache Tyan Thunder i7525 800 FSB 2 gig DDR II PNY QUADROFX 3450 74 gig, 10 000 SATA WD Raptor OS Drive 4 x 300 gig SATA Seagate... [view my complete system specs]
  • Thu, Aug 14 2008 11:18 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Yeah, I've been thinking alot about this series of effects shots and I'm slowly coming to realise there is a very easy way to do this. Someone else earlier in this thread already suggested this approach.  This effect can be accomplished by simply making sure the camera is locked down at an angle of between 30 to 45 degrees to the RIGHT side of the actor looking in the mirror. You can normally see his reflection completely and not see the camera or crew, yet now you have enough space to create a simple split-screen line. As long as the actor does not get too physically close to the mirror (thus crossing the split-screen line and ruining the illusion), then you just make a simple split screen line at the edge or just before the edge of the mirror and that split screen is the other locked down shot without anyone in the room. Et Viola !
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5, but had to roll back to 3.0.0. Also added Avid Studio Toolkit 5.7 running on.....HP... [view my complete system specs]
  • Fri, Aug 15 2008 2:23 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,496
    • Points 40,455
    Laptopeditor:
    jwrl:
    You could also do the effect in camera by rigging your mirror at 45 degrees and reflecting a duplicate, similarly dressed, background set.  No post production required.
     ....Huh ?Huh?Confused
    It's the basis of a series of old-time stage illusions.  By angling the mirror you can reflect an area of the room that is clear.  That way you can do the classic over-the-shoulder shot apparently front on to the mirror but not reflecting the actor (or crew for that matter).  As long as the image that you see in the mirror is consistent with your master shot it will work.
  • Fri, Aug 15 2008 6:40 AM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    jwrl:
     ...That's cool man ! Very cool ! Yes
