Latest post Wed, Aug 13 2008 5:41 PM by Ivo. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Aug 13 2008 11:27 AM
    • Ivo
    • Joined on Fri, Oct 21 2005
    • Germany
    • Posts 237
    • Points 3,135
    How can I see if the effect is really renderd in HD 10 bit uncompressed?
    In the clip is still the text DNXHD 185x. I set media creation "render" to MXF 1:1 10b. "same as source" is disabled.
    Avid Media Composer 3.0 Mojo SDI Win Vista 64 bit SP1 2x Quad core 3,0 GHZ 8 GB RAM NVidia Quadro FX 1500 14 TB storage S-ATA II intern... [view my complete system specs]
  • Wed, Aug 13 2008 1:05 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,505
    • Points 40,510
    Re: How can I see if the effect is really renderd in HD 10 bit uncompressed?
    I don't understand the question.  If your clip media is DNxHD 185x, it's 10-bit.  That's what the x suffix means.  If your render settings are set to 1:1 10b, then again when you render you should get 10-bit media.  So where does "same as source" come into it at all?
    Or are you asking whether there's a way that you can prove that Avid is doing what is claimed?
  • Wed, Aug 13 2008 1:10 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     If you create a bin heading for just "video" and go to your bin with the sequence containing the rendered effect, choose "show rendered effects" from the bin display options, what do you see for as the resolution for that particular effect?
  • Wed, Aug 13 2008 1:46 PM In reply to
    • Ivo
    • Germany
    • Posts 237
    • Points 3,135
    I thought "same as source" means if there is DNXHD 185x Avid will render DNXHD 185x but not 1:1 10b. Both 10b but uncompressed is still better. Or is it just that the 8bit to 16 bit setting in each effect will be overruled to always 16bit or 8bit?
    Yes I am looking for a prove what Avid is doing.
    Yes I can see that it rendered 1:1 10b., when I show rendered effects. Is there no other way to see it in the timeline?
  • Wed, Aug 13 2008 1:52 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     Yes there is. Go into the timeline fast (hamburger) menu and in "Clip text" select clip resolutions.
  • Wed, Aug 13 2008 5:41 PM In reply to
    • Ivo
    • Germany
    • Posts 237
    • Points 3,135
    Also after render it shows DNxHD 185, but I think it is rendered in1:1 10b.
