Latest post Thu, Aug 14 2008 12:49 AM by Ra-ey Saleh. 4 replies.
  • Tue, Aug 12 2008 5:56 PM
    • Red Ochre
    • Joined on Fri, Jan 27 2006
    • San Francisco
    • Posts 220
    • Points 2,805
    fixing iris change in middle of shot
    I need to fix an iris change in the middle of a shot. I'm using color effect and setting key frames but I'm not getting the best results. What do others do?
    MCA 2.7.2 (PC) and mojo MC 3.0 (mac) [view my complete system specs]
  • Tue, Aug 12 2008 6:07 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
    Re: fixing iris change in middle of shot
     Count the number of frames that define the actual iris change. Place an add edit at the halfway point. Apply a centered dissolve equal to that duration and color correct each segment appropriately. Done.
  • Wed, Aug 13 2008 8:41 PM In reply to
    • Red Ochre
    • San Francisco
    • Posts 220
    • Points 2,805
    Thanks for the advice Larry. That works for me some of the time but I just tried 3prongs Flicker Fix and WOW! Fast, effective and cheap!
  • Wed, Aug 13 2008 8:44 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     Yeah, I've been trying to get our people to acquire 3Prong for some time now. Maybe soon....
  • Thu, Aug 14 2008 12:49 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 343
    • Points 4,100
    Ok, I've been waiting for ages for someone to ask this, cause I have the perfect answer.
    But you have to have Sapphire.
    In the TIME tab, select 'S2_FlickerRemove'.
    Apply this to your shot.  Pick an area of the shot that doesn't change (i.e no one walks in front of it etc...).
    Reize the OnScreen widget and place the box over that area.  If the shot is moving, keyframe the box.
    Select all keyframes, park on the part of the shot that you want to match in Exposure and press the 'Set Hold Level' button.  The Hold Level parameter should change.  And Render.
    This can be a little quirky in HD.  So if you press the button, and the parameter doesn't change in munber; or when you render the exposure goes insane.  You're best off staring again, and reducing any unnecessary tweaks.  If you get it right it can iron out all exposure changes.
    (I once had a shot with 12 changes - some sharply on the 2nd field! - due to a faulty camera and this made the shot look perfect).
    My absolute best tip!
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
