Latest post Tue, Sep 2 2008 7:39 AM by Chad. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Fri, Aug 29 2008 2:10 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Re: Boris messing with gfx quality
    Motion Effects - Original Preference
    Timewarps - Blended Interpolated
    Effect Quality - Set in Each Effect.
    I tried promoting everything to HQ and it made no difference at all.
    MCA 2.8.3 on Dell 490 • 4GB Ram • Quadro FX3500 Driver 6.14.10.9185 • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. Edit monitor: Sony... [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Fri, Aug 29 2008 2:16 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     Well then if this issue is restricted to only Boris FX, I would think an uninstall/reinstall of Boris is in order. I can't think of any other option off the top of my head.
  • Fri, Aug 29 2008 2:57 PM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 396
    • Points 4,895
     Just a shot in the dark, but have you selected "better quality field rendering" in Boris FX? Also check the input output options in Boris FX.
    MC3.0.5, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo (FSB 1500MHz), 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX... [view my complete system specs]
  • Fri, Aug 29 2008 3:10 PM In reply to
    • Random Post
    • Toronto, canada
    • Posts 41
    • Points 515
     I know, I know, but I have to ask;
    On your system, are the BCC effects installed in the C:\program files\Avid\AVX_plug-ins  folder ?  That's where they should be.... they should not be in the C:\program files\Avid Media Composer\AVX2_plug-ins  folder.
    NOTE:  I had the same "field" look to rendered BCC effects when I installed BCC (by mistake) into the C:\program files\Avid Media Composer\AVX2_plug-ins.  BCC does not belong there.
    Hope this helps.
    Michel
    MC 3.0, Mojo SDI and Mojo analogue, approved Dell 670s config. 2Gb RAM, DVD, etc. D-Beta, BetacamSP, Sony DSR-45 DV/DVCAM, component'scope, monitors... [view my complete system specs]
  • Mon, Sep 1 2008 5:20 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Sorry guys, but we've already tried the re-install. No Joy.
    This is Boris Continuum Complete 4.2.2. All effects do go in the AVX 2 folder. If you move them to AVX 1, the menus cease to appear in Avid, the icons go blank and BCC FX no longer work. They're all AVX 2.
    There aren't any render or I/O options other than what Avid provides.
    It appears everyone is stumped by this one. Can that be true??
  • Tue, Sep 2 2008 7:39 AM In reply to
    • Chad
    • Joined on Fri, Oct 14 2005
    • Sydney, Australia
    • Posts 95
    • Points 1,100
    And you're sure it's not the Open GL issue?
    Avid MCA 2.7.7 on WinXP Sp2 HPxw8400 with 3GB Ram [view my complete system specs]
