Latest post Tue, Sep 2 2008 7:39 AM by Chad. 20 replies.
  • Tue, Aug 12 2008 3:02 PM
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Huh? [:^)] Boris messing with gfx quality
    I'm doing a simple logo anim on the timeline with elements prepared in Photoshop in the usual completely ordinary way. It's a regular standard def NTSC/30i project.
    I saved the merged multi-layer version in Photoshop, imported as sequence of layers, manipulated the layers on the timeline for the movements. Beautiful, no problem. (And no AE, which is why I am doing it this way).
    On an empty layer above everything, I have added the Boris Advanced Lens Flare. When I monitor without the lens flare, graphics are nice and crisp. When I monitor with lens flare (and render, of course) the graphics look like they are displaying a single field only.
    I have tried rendering everything. I have tried promoting all effects to HQ. I have tried altering parameters on the Boris Advanced Lens Flare. I have shut the system completely down, shut off the Adrenaline, restarted and re-launched Avid. Nothing makes any difference. No lighting FX, pretty graphics. Add lighting FX, ugly graphics.
    No changes have been made to the system, no software has been installed. The system was set up by our in-company Avid-trained folks. It has worked fine out of the box from day one.
    Your ideas and comments are welcome!
    MCA 2.8.3 on Dell 490 • 4GB Ram • Quadro FX3500 Driver 6.14.10.9185 • Avid rs146 x 2 striped as one • 2 internal 500 GB SATA drives. Edit monitor: Sony... [view my complete system specs]
    A gentle answer turns away wrath, but a harsh word stirs up anger. (Proverbs 15:1 NIV)
  • Tue, Aug 12 2008 4:03 PM In reply to
    • Random Post
    • Toronto, canada
    • Posts 41
    • Points 515
    Re: Boris messing with gfx quality
     Hello Paris MKVI,
    I once had the same problem after re-installing Boris after an Avid upgrade.  The problem was that I had installed Boris in the wrong AFX plugin folder.  There (were then) two folders for AVX plugins.  One of them is for (not in front of my machine now... I'm going by memory) AVX 1 and the other is for AVX 2.  I had installled Boris into the wrong folder.  Re-installing into the other folder, the correct folder, fixed the issue.
    Hope this helps.
    Michel
    MC 3.0, Mojo SDI and Mojo analogue, approved Dell 670s config. 2Gb RAM, DVD, etc. D-Beta, BetacamSP, Sony DSR-45 DV/DVCAM, component'scope, monitors... [view my complete system specs]
  • Tue, Aug 12 2008 7:30 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Hmmm, I'll look into it, thanks!
  • Tue, Aug 12 2008 7:35 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     And Boris should live in the AVX1 folder, that's where all my BCC plug-ins are.
  • Tue, Aug 12 2008 9:52 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    If they're not right, can I simply move them? Or will a re-install be required?
  • Tue, Aug 12 2008 9:56 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     No, you should just be able to move them into the AVX1 folder and re-launch and you'll be good to go. That is, as long as the Boris main application is already installed.
  • Wed, Aug 13 2008 3:03 AM In reply to
    • Chad
    • Joined on Fri, Oct 14 2005
    • Sydney, Australia
    • Posts 95
    • Points 1,100
    Some Boris effects are dependent on your Open GL hardware, and if you don't have the right card/driver combo, this can cause the sort of problem you are describing.  There is info on the Boris support site about this - if you can't find it - let me know here and I'll dig around and try to relocate it.
    (This was a problem I simply couldn't fix on my old xw8000, but now I'm on a xw8400 it's gone away)
    Avid MCA 2.7.7 on WinXP Sp2 HPxw8400 with 3GB Ram [view my complete system specs]
  • Wed, Aug 13 2008 4:52 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Hmmm. OK.
    Moving the plug-ins didn't fix it. Our BCC version is 4.2.2 and they're all AVX2. When I moved them to AVX1, their icons became blank and they did not work or generate effects menus. Moved them back and they work again.
    Our graphics card is an NVidia  Quadro FX3500, driver version 6.14.10.9185.
  • Wed, Aug 13 2008 4:59 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     That must have been changed between versions 3 and 4 then, because mine are in the AVX1 folder.
  • Fri, Aug 15 2008 2:55 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Anyone else have any ideas? I've had to put these spots on the air with substandard-looking graphics. I'd sure like to fix this.
  • Mon, Aug 18 2008 2:59 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    One last bump. . . any ideas folks?
  • Mon, Aug 18 2008 3:20 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
    Paris MkVI:
    Paris - can you bring your photoshop comp in as flattened and still do what you want creatively, to see if the problem persists? It's the only other idea I can think of at the moment.
  • Mon, Aug 18 2008 9:10 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    I cannot do that and manipulate the different logos elements separately, of course. But I'll try it anyway, just to see if it makes a difference. It would be an answer, even if it isn't one we'd like.
  • Fri, Aug 29 2008 2:03 PM In reply to
    • Paris MkVI
    • Norfolk, VA USA
    • Posts 356
    • Points 4,260
    Well, I tried that, and no joy. But get this - if I apply the lens flare to a piece of video, or the track above it, I get the same thing!  It looks like the video plays in single field mode.
    I am unable to post on PigsFly, and I am getting nothing on the Cow, not even a response. ANyone got any other ideas? Even our in-house corporate Avid IT is stumped.
  • Fri, Aug 29 2008 2:05 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     What quality option is chosen in the render settings in your user profile?
