Latest post Tue, Aug 12 2008 6:14 PM by flashpoint08. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Aug 12 2008 5:50 AM
    Help with After Effects footage in Avid
    I've been trying to import some motion graphics into Avid from AE, and the text is very jagged and trashy looking. In quick time and WMP the text is sharp and crisp but for what ever reasion I can not get the same look in Avid.
    I've tried every export setting I can thinking of, quicktime(no compression,various Avid codec's,DV,etc.) I've tried AVI uncompressed and it all looks fine in the media player like windows or quicktime. I've tried importing into avid as a A/V clip and as a matt, my Avid Import settings are as follows:
    601/ non square
    601 for color levels
    invert existing for alpha
    and non interlaced
    all files are comming in as OMF and under the OMFI setting I have it set use sourse resolution.
    Any help at all would be wonderful, thanks.
    Intel Core 2 Quad Q6600 @ 3.0GHz Kingston Hyper X RAM x 2GB Evga 780i Nforce Sli Evga 8800GTS 512 Seagate HDD's 320GB and 1TB [view my complete system specs]
  • Tue, Aug 12 2008 12:34 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
    Re: Help with After Effects footage in Avid
     For QT imports, your file field order option should be set for "even (lower) field first". The AE comp should be rendered out with the same field order.
  • Tue, Aug 12 2008 1:10 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Rankweil | Austria | Europe
    • Posts 217
    • Points 2,760
    Depends on where flashpoint08 is working? For a PAL project (SD or HD) user upper (odd) field first, for NTSC lower (even) first. As Larry mentioned the most important thing is, to use the correct field order durring both - export from AE and import to MC!
    Regards - Moses
    P.S.: Did you used the correct resolution in AE corresponding to your MC project?
    Avid Adrenaline DNxcel | HP xw8400 - Xeon CPU @ 2.66 GHz - 3GB RAM | easyRAID 4TB | MC 3.0.5 | PDW-U1 (Firmware 2.0) | DVW-M2000P [view my complete system specs]
  • Tue, Aug 12 2008 1:20 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,189
    • Points 73,915
     Moses is right - if PAL use upper field first. Since the poster is in US Eastern time zone, I assumed an NTSC product.
  • Tue, Aug 12 2008 2:04 PM In reply to
    • applebuckets
    • Pittsburgh, Pennsylvania
    • Posts 198
    • Points 2,525
    Larry Rubin:
     I almost never render fields in AE unless I have an existing video clip that requires it and it looks fine. IMO, graphics look more polished rendered as progressive. You just need to make sure field render is turned off.
    Not saying that's always the right way, I've just found it to look nicer overall.
    MCA 3.0 hp xw8200 3GB RAM Nvidia FX1300 MCA 3.0 hp xw8400 3GB RAM Nvidia FX1400 [view my complete system specs]
  • Tue, Aug 12 2008 6:14 PM In reply to
    yes I'm working with NTSC, and thanks for all the advice I'll give it try and see if that helps.
