Latest post Tue, Oct 7 2008 5:04 AM by BobbyMurcerFan. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Aug 7 2008 7:12 AM
    • Lowrider
    • Posts 99
    • Points 1,355
    Just Upgraded to MC3.0 - No Device Choices
    Trying to configure decks but when I try to add a deck on a Firewire on OHCI channel, there are no decks listed at all for any of the manufacturers. - "None Available"  Did I not load something right?
    Thanks.
    MC3, Dell T3400, Intel Core 2 Duo E8200 / 2.66 GHz, 2GB RAM, nVidia Quadro FX570, XP SP2 [view my complete system specs]
  • Thu, Aug 7 2008 4:37 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,826
    • Points 80,635
    Re: Just Upgraded to MC3.0 - No Device Choices
    It does indeed sounds like something went wrong. Best thing to do is uninstall Avid backup any projects or settings you want, rename-relocate or delete the Avid folder in Program files and re-install see if that clears things up. Also check the readme where there is quite extensive information on what might be needed to do when upgrading from 2.x to 3.x
    Menno
    MC 3.5.1 Test-Intel Core2Duo 6800,GTS8800 Nvidia,Realtek HD, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Oct 1 2008 2:58 PM In reply to
    I have the exact same problem going from 3.0 to 3.0.5. In 3.0 I had deck choices.
    In 3.0.5 I see a list of manufacturers but "None Available" is the only deck choice. Very strange. And of course I have material I want to capture.
    Auto configure in Deck Configuration does nothing at all. Show is set to "All Devices."
    P.S. I followed the uninstall directions from the Readme, including removing folders and registry keys. I reinstalled MC 3.0.5 and still no device choices. This is very frustrating, especially for a .0.5 upgrade. Any help is much appreciated.
    P4 3.0. 4 Gig RAM, CAS 2.0. 3Gig patch. Intel 865PERL mobo. Two WD 7,200 IDE drives. SIIG SATA II-150 PCI RAID card w/ 2 WD Raptor 10,000 SATA drives as... [view my complete system specs]
  • Fri, Oct 3 2008 8:08 PM In reply to
    I would LOVE some help with this. I really need to be able capture, but can't because there are no device choices.
    As I said above, I did a complete uninstall and reinstall following the directions in the Readme. Still no device choices.
    Please help.
    Thanks much.
  • Fri, Oct 3 2008 8:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,837
    • Points 201,255
    Best to give Avid a call on this one BMF....let them know what's going on and they'll get you fixed up.
  • Fri, Oct 3 2008 8:39 PM In reply to
    Should I call 1-800-800-2843 (got that number from avid.com), as I don't have support contract?
    I just purchased MC 3.0 (was using AXP 5.8.4) and it was working fine. The .0.5 upgrade started this problem.
    Thanks much.
  • Fri, Oct 3 2008 8:48 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,837
    • Points 201,255
    Yes, If you just purchased the software, you should have a code for one free support call to get setup.
  • Fri, Oct 3 2008 9:09 PM In reply to
    BTW, can you shed some light on if a complete uninstall of 3.0 is necessary/desireable when upgrading from 3.0 to 3.0.5? The 3.0.5 Readme is rather unclear. In some parts it seems to be talking about going from 2.7 to 3.0, not 3.0 to 3.0.5.
    (This point is being debated here: http://community.avid.com/forums/t/63747.aspx)
    I want to give this one last shot before calling Avid. I'm thinking of removing everything, user settings, ALL Avid folders and registry entries, etc. But should I install 3.0 and then 3.0.5 or go directly to 3.0.5? Perhaps 3.0 has some componets that 3.0.5 relies upon. IDK. If this one last try doesn't work, I'll give Avid a call.
    Thanks for your help.
  • Fri, Oct 3 2008 9:16 PM In reply to
    • Butcher
    • Joined on Mon, Apr 17 2006
    • Evansville, IN
    • Posts 1,331
    • Points 16,955
    BobbyMurcerFan:
    Go straight to 3.0.5.  It's a full installer--if you installed 3.0 first, you would then need to uninstall it to install 3.0.5.
    Avid doesn't give us patches or "upgrades" to previously installed software.  They just give you the entire program again to install.  Which is nice, because if you ever need to install an older version (or install it on another system) you don't spend all day installing version 2 then updating for in small increments for hours to get to 3.
    Michael.
    Dell Precision 490 Dual 3.2GHz Dual Core Processors (Hyper Threading disabled) 4GB RAM nVidia Quadro FX3450 driver 169.47 (nVidia driver supplied by... [view my complete system specs]
  • Sat, Oct 4 2008 1:32 PM In reply to
    • dbeditorial
    • Dallas, TX
    • Posts 19
    • Points 195
     Before you go throught the reinstall process, do yoiu see the tapedeck in the Windows Device Manager? It should be in listed under Imaging Devices. If Windows does not see the deck, Avid will not.
    Avid Symphony on NitrisDX and Media Composer on MojoDX. Both with BCC6. Protools 8.1 with Command 8 and an iLok full of goodies. Runs on a smoking fast... [view my complete system specs]
    "A person with no character has no enemies,
                                    so I prefer to make enemies."
     -- Paul Newman
  • Tue, Oct 7 2008 5:04 AM In reply to
    Oddly enough, Device Manager doesn't have a section for Imaging Devices, but the camera can still be captured from in Vegas (and now MC 3.0.5).
    I did a truly complete uninstall: Used Add/Remove programs, deleted all the remaining Avid folders and files I could find, deleted all Avid registry entries under HKey_Local_Machine and ran two registry cleaners.
    I also re-downoladed 3.0.5. The net result? I have a working version of MC 3.0.5 with device choices. I'm not sure what happened, but I imagine there was some leftover setting from the AXP version I uninstalled awhile ago that persisted and didn't work well w/ 3.0.5. I'll never know, but hopefully, this build will work smoothly.
    THANKS VERY MUCH for all the help offered here.
