Latest post Wed, Aug 13 2008 1:31 PM by Larry Rubin. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Aug 5 2008 1:16 PM
    Get Dissovle to Begin with Title Partially Showing
    I'm editing a child's tv show audition tape. I start the sequence with a dissolve effect fading up a title with the child's name.
    However, I'd like the title to faintly show at the very beginning of the sequence. I don't want to start with complete black because I want the viewer to know whose audition it is from the very first frame.
    I thought the Foreground value for the dissovle effect would adjust the starting opacity of the title, but I'm getting some odd results: Setting Foreground to a value other than 0 does change the starting opacity, but it also elminates any fading up--the title's opacity stays the same level for the length of the entire dissolve.
    And when I set Foreground back to 0, the title goes completely blank during the dissolve. To get the title dissolve to behave normally I have to Undo the changes to Opacity.
    Any thoughts are much apprecaited. Thanks.
    P4 3.0. 2 Gig RAM, CAS 2.5. Intel 865PERL mobo. Two WD 7,200 IDE drives and two WD Raptor 10,000 SATA drives--no RAID. nVIDIA Quadro FX 1100. Two EIZO... [view my complete system specs]
  • Tue, Aug 5 2008 1:25 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,013
    • Points 71,740
    Re: Get Dissovle to Begin with Title Partially Showing
     You need to adjust the foreground level on the title clip itself, not the dissolve effect. You will need to add at least one additional keyframe and adjust foreground level to a different value than the first keyframe to see a change. The distance between keyframes determines the speed of the fade. To move keyframes left or right, ALT drag.
  • Thu, Aug 7 2008 9:40 AM In reply to
    • indigospin
    • Lubbock, Texas, USA
    • Posts 347
    • Points 3,825
     larry's right.  you need to use keyframes to fade-in your title instead of a dissolve.  that way you can hold the "foregroung" level where you want it for as long as you want it before "fading up" to 100%.  if you are not familear with adding & editing key frames, just ask here & someone will likely chime in fairly quickly.
    shane
    ASUS M2N32-SLI Delux MOBO, AMD Athlon 64 X2 Dual-Core 4600+ 2.41 GHz, 3.5 GB RAM, Windows XP Pro SP2, NVIDIA QuadroFX1300 (driver 84.26... [view my complete system specs]
    staffer: "How do you go without sleep for so long?" me: "Not nearly as well as I used to."
  • Thu, Aug 7 2008 3:05 PM In reply to
    For a quick and dirty way to "dissolve" Titles, use Fade Effect, then to change the params, just go into the Effect Editor and adjust the Foreground as described above.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Aug 13 2008 1:26 PM In reply to
    I think I got it working. What was causing me problems was not having the cursor on the first keyframe when adjusting the Foreground value.
    You guys ROCK!
  • Wed, Aug 13 2008 1:31 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,013
    • Points 71,740
     Glad to hear it.
