Latest post Wed, Aug 6 2008 2:22 AM by Mondo. 4 replies.
  • Sun, Aug 3 2008 5:34 PM
    • Edit2007
    • Joined on Tue, Dec 5 2006
    • Posts 57
    • Points 710
    looking for info on Mojo SDI getting disconnected..
    anyone have info on a forum discussion talking about my problem again...Mojo SDI gets disconnected (offline) everytime I restart or turnoff my computer... HP 8200 Mojo SDI 4GBRam DUal 3.2HZ XP pro 32bit separated 1399 PCI card for the Mojo
  • Tue, Aug 5 2008 1:08 AM In reply to
    • avidmedic
    • Joined on Mon, Jan 30 2006
    • Atlanta, ga
    • Posts 51
    • Points 555
    Re: looking for info on Mojo SDI getting disconnected..
    Are you running gigabit ethernet?  Is your firewire card in the third slot from the bottom? From your description it seems clear, but are you running any firewire devices?
    How are they connected?
    You name it, I've seen it. [view my complete system specs]
  • Tue, Aug 5 2008 2:10 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 183
    • Points 2,100
     I think the generally accepted config is to run the Mojo of the mboard's firewire port and any external drives off the card. FW Card must be on a separate PCI segment (to mb fw and network and any scsi storage). I'd also try swapping cables if nothing else works. Must be a TI OHCI set as well.
    Adrenaline HPXW8400 3gig RAM FX1500 Mojo Analogue HPXW8000, 3GIG RAM, 380 storage Quadro FX3000 Unity 4.2.3 with 8 terrabytes of storage [view my complete system specs]
    John
  • Tue, Aug 5 2008 4:09 PM In reply to
    • Edit2007
    • Posts 57
    • Points 710
    running Mojo SDI out of third slot from the bottom...this PCI card has 3 firewire connections I am using only one for the Mojo. I have an Ethernet cable (internet)also, and I am using a (besides my old LVD drives using the back connection (B) of the HP) a 500 GB Lacie using USB 2.0 and a small Lacie 125 GB using the firewire in the back of HP. Must be a TI OHCI set as well....? please explain when you can, thank you.
  • Wed, Aug 6 2008 2:22 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 183
    • Points 2,100
     TI = Texas Instruments (chipset manufacturer)
    Please reverse your configuration and run the Mojo from the onboard firewire and the hard drives from the outboard card and try a new firewire cable.
    John
