Latest post Thu, Aug 7 2008 10:11 AM by indigospin. 4 replies.
  • Sat, Aug 2 2008 12:22 AM
    • Playerpat0
    • Joined on Fri, Oct 5 2007
    • Posts 5
    • Points 85
    Export Uncompressed
    Hello.
    I am trying to export and burn a DVD with no compression. I shot super 16 and transferred via DVC Pro HD. I have no idea how to export with no compression (quality loss). Any help on how to do this and the steps to take would be great.
    I read on another post that you could perform a mixdown and then export. I am trying this now and would appreciate any help that can be given.
    Patrick
    Filed under: , ,
  • Sat, Aug 2 2008 12:31 AM In reply to
    Re: Export Uncompressed
    DVD's "must" be compressed.  DVD players cannot play uncompressed files.  The maximum bitrate for a DVD is 9.8 Mb/s, although most encoding is typically 7-8Mb/s
  • Sat, Aug 2 2008 12:36 AM In reply to
    • Playerpat0
    • Posts 5
    • Points 85
    Ok. So what is the best method for moving a 4gig short film to DVD without losing quality? I also want to transfer into an effects program, but without any quality loss. I tried using the AVI function and it disrupts and the quality is very poor. Any suggestions? I can get a DVD but with strong amounts of compression. I want the final product as uncompressed as possible thanks.
     Edit: I just tried exporting as a movie, and received a console error message. Then it said a directory on my drive f. was not there.
    What is going on here?
  • Sat, Aug 2 2008 12:49 AM In reply to
    Probably the best way to xfer the media to your FX program is via QT Rerference.  As for encoding for DVD's that's a huge subject, and has been covered in detail.  There used to be a post with all the tips & tricks, but I can't find it.  Perhaps somebody else will chime in with the link ....
  • Thu, Aug 7 2008 10:11 AM In reply to
    • indigospin
    • Lubbock, Texas, USA
    • Posts 358
    • Points 3,910
     what happened to that page on dvd settings??  i just check a link i had saved to a post detailing my dvd workflow (from a post long ago) & it says "this post no longer exists".  i hope all posts from more than a year ago don't "cease to exist"...
    and randall is right, it totally depends on the programs you are using to compress, author, etc.
    as for quality, find a program (like Sorenson Squeeze) that will allow you to encode to Mpeg2 from a QT Ref file (without any additional compression or format-changes), then encode it at the highest data rate you can afford.  if it's less than 60 min., has no more than 2 audio tracks & you don't need any additional tracks on the dvd (such as menus, etc.) then 8000 Kbps with an i-frame rate of 6 or lower (sometimes lower can look screwy) should look as close to "uncompressed" as possible (using a software encoder).  if you're using Sorenson, you will also want to DEactivate the Auto-Deinterlacing (by adding a filter with only that setting disabled).  that, in a nutshell, should get you looking pretty good.  that said, a havn't found a software encoder that can compress as efficiently and cleanly as the high-end, hardware encoders used by the "big boys".  (although the difference is marginal if you know how to optimize your software app.)
    good luck!
    *EDIT* i just found this link that had a bunch of good dvd stuff.  scroll down to the heading "HOW TO DVD":   http://community.avid.com/forums/t/997.aspx
    shane
    ASUS M2N32-SLI Delux MOBO, AMD Athlon 64 X2 Dual-Core 4600+ 2.41 GHz, 3.5 GB RAM, Windows XP Pro SP2, NVIDIA QuadroFX1300 (driver 84.26... [view my complete system specs]
    staffer: "How do you go without sleep for so long?" me: "Not nearly as well as I used to."
