Latest post Thu, Mar 11 2010 10:38 PM by editorbelga. 15 replies.
  • Fri, Aug 1 2008 5:31 PM
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 361
    • Points 4,440
    Distorted Analog Audio Nitris DX hardware
    Hello All,
    Has any one else noticed the lower headroom on analog audio as compared with the Adrenaline? I see it on both normal outputs and monitor outs. I can't seem to get audio that is hotter than -14 to pass without any audible distortion. I have 2 DX boxes and they both do the same thing. Audio levels are set to 0 on both audio out and monitor out.
    Mark
    Media Composer Nitris DX 4.0.5 Dual 3GHz Mac Pro 4GB Ram 10.5.7,Symphony Nitris DX 4.0.5 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Media Composer Adrenaline HD... [view my complete system specs]
  • Fri, Aug 1 2008 6:20 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,828
    • Points 23,215
    Re: Distorted Analog Audio Nitris DX hardware
    Is the hardware calibration set to -14 or -20?
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Fri, Aug 1 2008 6:32 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 361
    • Points 4,440
    Hardware calibration is set to -20.
  • Tue, Aug 5 2008 11:26 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 361
    • Points 4,440
    bump
  • Wed, Aug 13 2008 9:35 PM In reply to
    • rferguson
    • Joined on Wed, Jun 11 2008
    • Posts 13
    • Points 150
    What are all the settings you have in the Hardware Calibration pane?
    Audio Project-> Hardware Tab-> Hardware Calibration Button
    If you play tone do you hear the distortion?
    Best,
    Rob Ferguson
    Audio Software Engineer Avid Tewks
  • Wed, Aug 13 2008 10:51 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 361
    • Points 4,440
    I do not hear distortion playing  tone.I have attached an image of my Hardware calibration.
  • Wed, Aug 13 2008 11:10 PM In reply to
    • jal
    • Posts 13
    • Points 165
    This is curious.
    I assume that when you say it clips at -14dBfs, you are getting that value from the audio tool's meters, right?  You hear it distort when the meter values goes higher than -14?
    There are two other places that can apply gain, the "clip gain", either on the source clip or in the sequence, or "gain automation".  However, in either case, or with the "output gain" set in the Audio Project settings, you would see the result of this gain in the meters in the audio tool.
    You can also get "gain" if the audio mix, is mixing phase coherent channels into the same output. So, if you have two copies of the same audio on two different tracks, and both are mixed to the same output channel, it will appear as 6dB of gain, but again, this will will be visible in the audio tool's meters.  (Does this happen with only one track playing?)
    What you don't see in the meters is gain applied by the "volume" slider.  This gain applies to the monitor outputs (1/4") and to the Headphone outputs, but only applies to the XLR output is you are using them for 6-channel surround monitoring.  If you crank that up you can get clipping when the level exceeds whatever you set it for - if you set it to +12 it can clip when the media plays at -12dBfs.
    I know, you said this slider was at zero, but on a whim, try moving it to -1.   If that works, move it back to 0 again, and report back.
  • Thu, Aug 28 2008 3:41 PM In reply to
    I am also having audio distortion on the XLR audio output. I have found that if I change the audio port calibration on the analog output to -4.00 from the 1.0 default, it  takes care of it.  What is the correct  level to set this? Is there a manual for the Nitris DX?
    Thanks for any help.
  • Thu, Aug 28 2008 3:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 16,543
    • Points 210,035
     You are correct Doug. A bunch of us noticed this in Beta too. We had to drop the calibration from the default level. We reported it to Avid and hopefully the'll have a fix in one of the firmware updates.
  • Wed, Mar 25 2009 9:36 PM In reply to
    • Cate
    • Joined on Sun, Jan 1 2006
    • Posts 17
    • Points 270
    I've just now run across this issue -  I'm running v3.1.2.  No fix yet?
  • Fri, Mar 27 2009 3:09 AM In reply to
    • rljohnson
    • Joined on Sun, Oct 22 2006
    • Posts 39
    • Points 455
    I'm glad to see that others are hearing this distortion also. We noticed it on our Nitris DX Symphony and was trying to determine if we had another problem going on. I have my setting at -20db and use the analog out for monitoring. Most everthing I master is SDI with audio embedded. I'm running 3.1.1
    Rodney L Johnson Creative Services Senior Editor Pittsburgh
  • Fri, Mar 5 2010 8:13 PM In reply to
    Did this ever get fixed?
    thanks
    wim
    HP XW8600 - 2x Quadcore 3.00Ghz - 8GB RAM - Nvidia Quadro FX3700 - Avid Media Composer 4.0.5.1 + Nitris DX - Windows Vista Business 64bit SP 1 - PDW-U1 [view my complete system specs]
  • Fri, Mar 5 2010 8:15 PM In reply to
    and was this an issue only in Symphony, or also in Media Composer?
    (will be receiving my nitris dx soon, so want to prepare myself...)
    wim
  • Fri, Mar 5 2010 8:46 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 361
    • Points 4,440
    i don't know if it was fixed or not. I stopped using the XLR line out and use the monitor out which doesn't seem to have the problem. We saw it on both Symphony and Media Composer.
  • Fri, Mar 5 2010 8:51 PM In reply to
    I hope it is fixed... I am really going to need those XLR outputs!
