Latest post Thu, Aug 28 2008 3:47 PM by BLKDOG. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Aug 1 2008 5:31 PM
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 60
    • Points 755
    Distorted Analog Audio Nitris DX hardware
    Hello All,
    Has any one else noticed the lower headroom on analog audio as compared with the Adrenaline? I see it on both normal outputs and monitor outs. I can't seem to get audio that is hotter than -14 to pass without any audible distortion. I have 2 DX boxes and they both do the same thing. Audio levels are set to 0 on both audio out and monitor out.
    Mark
    Media Composer Nitris DX 3.0.5 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.5, Symphony Nitris DX 3.0.5 Dual 3GHz Quad Mac Pro 4GB Ram 10.5.5, Unity MediaNet... [view my complete system specs]
  • Fri, Aug 1 2008 6:20 PM In reply to
    • TCurren
    • Posts 1,137
    • Points 14,685
    Re: Distorted Analog Audio Nitris DX hardware
    Is the hardware calibration set to -14 or -20?
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
  • Fri, Aug 1 2008 6:32 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 60
    • Points 755
    Hardware calibration is set to -20.
  • Tue, Aug 5 2008 11:26 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 60
    • Points 755
    bump
  • Wed, Aug 13 2008 9:35 PM In reply to
    • rferguson
    • Joined on Wed, Jun 11 2008
    • Posts 10
    • Points 130
    What are all the settings you have in the Hardware Calibration pane?
    Audio Project-> Hardware Tab-> Hardware Calibration Button
    If you play tone do you hear the distortion?
    Best,
    Rob Ferguson
    Audio Software Engineer Avid Tewks
  • Wed, Aug 13 2008 10:51 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 60
    • Points 755
    I do not hear distortion playing  tone.I have attached an image of my Hardware calibration.
  • Wed, Aug 13 2008 11:10 PM In reply to
    • jal
    • Posts 13
    • Points 165
    This is curious.
    I assume that when you say it clips at -14dBfs, you are getting that value from the audio tool's meters, right?  You hear it distort when the meter values goes higher than -14?
    There are two other places that can apply gain, the "clip gain", either on the source clip or in the sequence, or "gain automation".  However, in either case, or with the "output gain" set in the Audio Project settings, you would see the result of this gain in the meters in the audio tool.
    You can also get "gain" if the audio mix, is mixing phase coherent channels into the same output. So, if you have two copies of the same audio on two different tracks, and both are mixed to the same output channel, it will appear as 6dB of gain, but again, this will will be visible in the audio tool's meters.  (Does this happen with only one track playing?)
    What you don't see in the meters is gain applied by the "volume" slider.  This gain applies to the monitor outputs (1/4") and to the Headphone outputs, but only applies to the XLR output is you are using them for 6-channel surround monitoring.  If you crank that up you can get clipping when the level exceeds whatever you set it for - if you set it to +12 it can clip when the media plays at -12dBfs.
    I know, you said this slider was at zero, but on a whim, try moving it to -1.   If that works, move it back to 0 again, and report back.
  • Thu, Aug 28 2008 3:41 PM In reply to
    I am also having audio distortion on the XLR audio output. I have found that if I change the audio port calibration on the analog output to -4.00 from the 1.0 default, it  takes care of it.  What is the correct  level to set this? Is there a manual for the Nitris DX?
    Thanks for any help.
  • Thu, Aug 28 2008 3:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,278
    • Points 180,890
     You are correct Doug. A bunch of us noticed this in Beta too. We had to drop the calibration from the default level. We reported it to Avid and hopefully the'll have a fix in one of the firmware updates.
