Latest post Fri, Aug 15 2008 11:04 AM by tom_e. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Aug 1 2008 7:57 AM
    • tom_e
    • Joined on Fri, Feb 10 2006
    • munich, germany
    • Posts 129
    • Points 1,495
    audio stutter on QT export
    when exporting quicktimes I recently get a bad stutter in the audio, it sounds like having caps lock on and scrolling slowly through a track - every second frame is missing or maybe it´s two on - two off. I put an example with tone media here
    http://community.avid.com/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.03.89.66/TONE--1000-Hz-_4000_-_2D00_14.0-dB.1.zip
    I tried setting the project to different sample rates cause I thought maybe sr conversion is hickupping, it helped once and this morning stutter was back. It occurs on exporting qt uncompressed and ima4:1, the compressions I usually use. I got QT 7.4.5. Sometimes playback sounds the same with me, I think it comes from putting the computer into hibernation (which I know is not supported, but well, wont have it run all day when not used and booting takes time, too. I think export is software-only and should not be involved with my sound card?).
    My current workaround is to export a wave or aiff and stick it to the video using qt pro...
    anyone had this before?
    thanks,
    thomas
    Asus P5B, Core2Duo 2,67, 3GB Ram, Quadro FX 3400, Creative SB X-Fi Music. XP Pro SP2. Media Composer 3.0. [view my complete system specs]
  • Fri, Aug 1 2008 8:14 AM In reply to
    • camoscato
    • Posts 4,795
    • Points 57,245
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: audio stutter on QT export
    Hi Thomas,
    tom_e:
    If you've noticed that the problem happens after putting the computer into hibernation, and you know putting the computer into hibernation isn't supported, I think you ought not to put the computer into hibernation.
    good luck,
    Carl
  • Fri, Aug 1 2008 8:22 AM In reply to
    • tom_e
    • munich, germany
    • Posts 129
    • Points 1,495
    Hi Carl, I just too late thought about posting that even after a restart the problem is still there, so I don´t think it´s originating from hibernation... Any other guess?
    Thomas
  • Fri, Aug 1 2008 8:25 AM In reply to
    • tom_e
    • munich, germany
    • Posts 129
    • Points 1,495
    I meant the playback stutter that I also sometimes experience comes from hibernation...
  • Sat, Aug 2 2008 2:28 AM In reply to
    • tom_e
    • munich, germany
    • Posts 129
    • Points 1,495
    am I the only one with this issue?
  • Sat, Aug 2 2008 2:39 AM In reply to
    Depending on the size (frame size and file size) of the QT movie, it may stutter audio and video on PC.
    Try reducing the QT player window down to a postage stamp size and see if it still occurs.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Sat, Aug 2 2008 11:21 AM In reply to
    • tom_e
    • munich, germany
    • Posts 129
    • Points 1,495
    Kenton,
    it got nothing to do with data rate. Geeked
    I created tone media using the audio tool and exported that as mov (ima 4:1, should be capable to play that on my pc Big Smile), even without video the stutter is there. I posted a link to it in my original post, cause I did not understand how to attach the file to the thread...
    any other idea?
    Confused
  • Tue, Aug 5 2008 7:39 PM In reply to
    • tom_e
    • munich, germany
    • Posts 129
    • Points 1,495
    bump?
  • Fri, Aug 15 2008 11:04 AM In reply to
    • tom_e
    • munich, germany
    • Posts 129
    • Points 1,495
    well after a lot of Angry
    I went back to quicktime 7.1, now export works...  Confused
    Smile
    thomas
