Latest post Mon, Aug 11 2008 11:22 AM by Blue Crow. 2 replies.
  • Fri, Aug 1 2008 3:31 AM
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 445
    • Points 5,385
    Ghost Images of Systems ?
    I ghosted images of different types of systems as a back up and when I have had hard drive errors I've put the ghost back on which has worked quite well as a quick fix.
    I then run a system id number change programme along with creating a new unique user before inputting the original key codes for software , Boris etc.
    So far I don't appear to have had any problems because of this but I was wondering if anyone else had ? I heard from somebody recently that if you use Interplay with machines that have been ghosted things don't work that well. Has anyone any experience of this ?
    I'd be gratful of any info or advice anyone has.
    Thank
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
  • Sat, Aug 2 2008 3:43 PM In reply to
    • avidmedic
    • Joined on Mon, Jan 30 2006
    • Atlanta, ga
    • Posts 51
    • Points 555
    Re: Ghost Images of Systems ?
    I just installed 20 Interplay client systems using Ghost, and use it almost every day.
    The biggest thing to do is run the SID utility, and change machine names and IPs.
    You name it, I've seen it. [view my complete system specs]
  • Mon, Aug 11 2008 11:22 AM In reply to
    • Blue Crow
    • Posts 445
    • Points 5,385
    Thanks for the reply avidmedic. I have followed the procedures you mention to the letter so I think I should be able to discount the ghostimage being our problem.
    Basically we thought the
    "exception get media domain type () - unable to get domain type because locater is null " which I posted
    http://community.avid.com/forums/p/61014/343408.aspx#343408
    was potentially brought about by ghosting and maybe that we should do complete installs in future.
