Latest post Mon, Aug 4 2008 3:31 PM by dan10k. 2 replies.
  • Thu, Jul 31 2008 3:41 PM
    • dan10k
    • Joined on Sun, Jul 9 2006
    • Posts 20
    • Points 250
    Problems capturing JVC-shot footage - please help!
    I'm working with MIni-DV tapes, PAL, capturing through my Canon XM2, and with tapes shot with a Canon XL-1. These tapes capture fine, but when trying to capture the same kind of tape with footage shot from a JVC GY-HD100, the composer seems to freeze when trying to capture. The tape keeps playing through the capture window but vision and sound are cut off.
    Is there some kind of setting I need to adjust to get footage shot with the JVC to capture? Both are 25-frames, PAL, shot on Mini-DV. I'm using Xpress Pro 5.8.
    Thanks for any help.
    -Dan
    Windows XP Professional Sp3 2x 150GB Hard Drives 4GB RAM (recognising 3.25) Intel Core 2 Duo CPU E6850 @ 3.00GHz ASUS P5K AiLifestyle Series iP35 Socket... [view my complete system specs]
  • Thu, Jul 31 2008 7:38 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,660
    • Points 78,890
    Re: Problems capturing JVC-shot footage - please help!
    I think you are in bad luck. We have had many situations where DV footage shot on a Sony for instance was not playable on a different sony even though it was the same model. If the heads of the JVC where slightly out of allignment you are in trouble on another camera.
    See if the playback from the camera works by connecting it to a tv or monitor.. if that works hmm.. next thought Smile
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Mon, Aug 4 2008 3:31 PM In reply to
    • dan10k
    • Posts 20
    • Points 250
    Playback works fine through TV and even plays fine when watching back in Avid. It's only when it comes to actually clicking capture that it freezes and fails to capture anything. If I can't get round this using Avid can anybody recommend a program that won't have this problem, and will capture in 16:9 DV-AVI? I could install Adobe Premiere Pro but it seems a little wasteful if I'm just going to be importing it then into Avid.
