Latest post Thu, Jul 31 2008 12:48 PM by Ken Larsen. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jul 31 2008 12:22 AM
    • Ken Larsen
    • Joined on Mon, Jul 28 2008
    • Minnesota, USA
    • Posts 14
    • Points 200
    length of jpeg image in timeline
    I'm doing a green screen effect.  The talent is in front of a jpeg image of a set.   How do I  set the length of time the still image is on the timeline to match the length of the clip containing the talent?
    I'm accustomed to Liquid, where you just drag it out to the desired length.  So far I have been unable to find the equivalent function in MC.
    Thanks for any input.
    Ken
    PC, Intel quad core, 8 gigs ram, bunch of HD space. [view my complete system specs]
  • Thu, Jul 31 2008 12:28 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,184
    • Points 73,840
    Re: length of jpeg image in timeline
     When you import your JPEG file into the project using the import tool, the import tool options allow you to create a clip up to 60 seconds in length. If you need it to be longer, you can mount the imported clip into the source monitor, mark an in anywhere, and choose "freeze frame" from the clip menu. In that freeze frame menu, you can custom define a longer duration if you need to. For a JPEG image, I would suggest the "use both fields" option when creating the freeze frame.
  • Thu, Jul 31 2008 1:01 AM In reply to
    • editz
    • Eugene, Oregon
    • Posts 65
    • Points 805
    Perhaps a simpler method would be to just edit in another piece of the same jpeg clip into your timeline.  No need to worry about freezing stuff.
    MCA 2.2.10 XW8000 dual 3.0GHz, 2GB RAM, NVIDIA 980 [view my complete system specs]
  • Thu, Jul 31 2008 2:25 AM In reply to
    editz:
    That's what I'd do as well.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Thu, Jul 31 2008 7:26 AM In reply to
    Just tried it out to make sure, but that entry is not limited to 60 seconds. 200 seconds also worked. When I entered a bunch of 9's, the Avid told me that I could not go above 21600 seconds. That resulted in a 6-hour clip.
    MC-soft 2.8
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Thu, Jul 31 2008 12:48 PM In reply to
    • Ken Larsen
    • Minnesota, USA
    • Posts 14
    • Points 200
     Thank you.  That was exactly what I needed and it worked.  As another post pointed out, the length is not limited to 60 secondse.
    This sort of exchange of bits of knowledge in this forum is a wonderful gift.   Thanks again.
    Ken.
