Latest post Mon, Sep 15 2008 10:26 AM by tonyjover. 17 replies.
  • Wed, Jul 30 2008 4:39 AM
    How do I keep the resolution??
    hi everyone,
    I'm new to the forum and also new to DS (as you'll probably guess from my lame questions!)
    hope someone can help:
    ok so, i'm working on a project that is solely utilising high res stills and basically cutting the foreground out from the background and animating them to give a 3d look. this part i'm fine with....
    however, the client would like the images to start off very close in and drift backwards into frame. this i'm not....!!!
    how is it possible to maintain the resolution on the animating stills?
    kind regards
    craig
  • Wed, Jul 30 2008 4:19 PM In reply to
    • NP
    • Edmonton
    • Posts 48
    • Points 545
    Re: How do I keep the resolution??
     Link to the stills rather than capture them
  • Fri, Aug 1 2008 4:32 AM In reply to
    • HDhead
    • Joined on Sat, Mar 29 2008
    • Los Angeles
    • Posts 26
    • Points 325
    Yes, to clarify the response, when you capture file based sources like still images DS will capture them at the current resolution so you will get the same thing you get in Media Composer or Symphony.
    However, if you link to the files they will remain true to their native resolution. If your files are very large you can zoom in quite close. And the best thing about linking is that you can swap out the files by simply overwriting or renaming them.
    www.HDhead.com HD and D-cinema Consulting
  • Wed, Aug 13 2008 3:21 AM In reply to
    Thanks for your responses guys. Very helpful and have been flying ever since...
    However..... I would now like to be able to matte shape the high res image and animate it, keeping the resolution. Unfortunately I can't seem to find a way of accessing the whole high res image to draw my matte shape as I only have the portion of the frame to work with (pal frame)?? I can resize it to pal frame then cut it out, then animate it but I then lose the resolution once i blow it up again?
    please help
    kind regards
    craig
  • Wed, Aug 13 2008 4:21 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 271
    • Points 3,310
    Link to the image, cut it into your sequence, put a matte effect on that clip, open the matte effect and view the whole frame ( you should see the whole hi rez image), cut you matte, add DVE, animate.
    Make sense?  Good luck,
    Jef
    Mac Dual 2.8 8core ATI2600 OS 10.4.11 /10.5.5 10 GB ram 2xSATA software raid local storage PC - Dell 360 3GHz XPPro 2.5 GB ram, local SATA storage [view my complete system specs]
  • Wed, Aug 13 2008 7:39 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 260
    • Points 2,840
    • Moderator: Avid DS
    Check your options tab on the Matte effect. If you have "output frame size" checked, DS will crop the image to the current frame size. It helps with render times, as it only calculates what is inside the frame. So, turn it off to create your matte, turn it on before you make your final render.
    Michael
    "There are no rules for the brave". Albert Einstein
  • Wed, Aug 13 2008 10:35 PM In reply to
    • jef
    • Maryland
    • Posts 271
    • Points 3,310
    What Michael said.  I was in a hurry when I wrote my quicky recipe.
    Cheer,
    Jef
  • Wed, Aug 13 2008 11:32 PM In reply to
    thanks for all the help guys... much appreciated!!!
    all the best
    c
  • Thu, Aug 14 2008 3:38 PM In reply to
    • tonyjover
    • Birmingham UK
    • Posts 76
    • Points 745
    mrmikster:
    Hey Michael, you weren't thinking that through.... he'll need to keep it unchecked on his Matte Effect.
    Cheers,
    Tone :)
    DS v10 x 2, MC (various), DS beta tester [view my complete system specs]
  • Fri, Aug 15 2008 5:20 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 260
    • Points 2,840
    You're right, I missed the part where he is going to translate the image after the matte has been cut. Keep the "output frame size" unchecked on the matte effect.
    Michael
  • Thu, Sep 11 2008 11:22 PM In reply to
    hi guys,
    thanks for the help so far, much appreciated!!
    have managed to make the matte shapes using the matte track effect which is great, however i don't seem to be able to view the whole frame using matte effect in composite mode? as i'm doing alot of 'tree' work that would be preferable or do i just have to stick to the track effect, make my shapes, save them, then apply them into the composite???
    thanks in advance
    c
  • Fri, Sep 12 2008 2:02 AM In reply to
    • jef
    • Maryland
    • Posts 271
    • Points 3,310
    Make sure you turn the same Output Frame Size switch in the Composite node and the slice node.  That gets me all the time.
    I do lots of tree stuff all the time as well this way.  It is just a matter of finding all the places that can restrict the frame size.
    Jef
  • Fri, Sep 12 2008 9:11 AM In reply to
    • tonyjover
    • Birmingham UK
    • Posts 76
    • Points 745
    jef:
    you turn the same Output Frame Size switch {off}
    However, be careful and think about what you are doing.  DS doesn't care (within reason) how big your image is, but your rendering times certainly do.  Think about it - if DS calculates a 720 x 576 image then it has around 415,000 pixels to manipulate.  Double the image size and it has 1.6 Million pixels to calculate.
    So, what's my point? It is to only turn Output Frame Size off where necessary and only on those nodes that MUST have it turned off.
    Here's an example - a large linked image that needs to be cut out with a Matte node and then DVE'd around.  The ONLY node that needs to have Output Frame Size turned off in this example would be the Matte node.
    Regards,
    Tone :)
  • Fri, Sep 12 2008 11:35 PM In reply to
    • jef
    • Maryland
    • Posts 271
    • Points 3,310
    Tony is correct.
    I have seen editors setup trees that literally would not render.  But with a bit of refining and placing "Output Frame Size On" turned on at strategic point made it doable.
    Jef
  • Sun, Sep 14 2008 7:27 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 260
    • Points 2,840
    And don't forget, judicious use of cache nodes in a complex tree can be a real timesaver.
    Michael
