Latest post Wed, Jul 30 2008 8:11 PM by babyblue. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jul 29 2008 7:34 PM
    • babyblue
    • Joined on Fri, Oct 5 2007
    • Rio de Janeiro Brazil
    • Posts 58
    • Points 755
    deck problems
    PENTIUM QUAD CORE,  8 GBYTES MEMORY, VIDEO BOARD MSI 9800, 4 SATA-3 750GBYTES EACH, FIREWIRE TEXAS INSTRUMENT.
    We are updating to MC 3.0 and have had the follow problems.
    We conected the HDV DECK Sony model HVR M25U via mojo in our system.
    When I tried to configure the deck for the correct model, and them go to capture tools, AVID does not recognize the deck, " message  NO DECK"
    I am setting my channel on the deck  configuration  to firewire on AVID DNA.
    Should I need to configure my video imput to DNA 1394 or component?
    I need to finish a vey important  job, and here in Brazil no one to help.
    Thanks very muck
    aLLAN
    MC 3.0 - Pentium quad core, 8 gbytes memory, MSI 9800 VIDEO BOARD, 4 SAT-3 HARD DISC(750GBYTES EACH), AUDIO CONTROLLER, IDT high definition audio codec... [view my complete system specs]
  • Tue, Jul 29 2008 10:26 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,166
    • Points 73,575
    Re: deck problems
     If your only connection between the deck and the platform is firewire then yes, you video input should be configured for 1394. If you are connecting analog R, G and B cables from your deck to the mojo, then the input would be configured for component.
  • Wed, Jul 30 2008 9:34 AM In reply to
    • PPavel
    • Joined on Fri, Jun 9 2006
    • Brno, Czech Republic
    • Posts 50
    • Points 610
    Re: deck problems
    Make sure (in deck's setup) the deck doesn't downconvert the HDV do DV. Sometimes it's useful to switch the deck's format from Auto to HDV. The windows should recognize the deck firstly, then you can use it in Avid. If connection thru the Mojo doesn't work, try disconnecting Mojo, reboot and connect deck directly to your computer.
    PP
    MC 3.0.5, Mojo, Dell 670, 2x Xeon 3.2GHz, 2GB RAM, nVidia Quadro FX4000, Win XP SP2 [view my complete system specs]
  • Wed, Jul 30 2008 12:22 PM In reply to
    • babyblue
    • Posts 58
    • Points 755
    Re: deck problems
     Thanks for the tip, too late today to give a try
    After long 24 hours non sleep, I will try tomorrow.
  • Wed, Jul 30 2008 2:16 PM In reply to
    • applebuckets
    • Pittsburgh, Pennsylvania
    • Posts 198
    • Points 2,525
    Re: deck problems
     One other thing, try connecting your firewire cable to a card rather than throguh the MOJO.
    MCA 3.0 hp xw8200 3GB RAM Nvidia FX1300 MCA 3.0 hp xw8400 3GB RAM Nvidia FX1400 [view my complete system specs]
  • Wed, Jul 30 2008 8:11 PM In reply to
    • babyblue
    • Posts 58
    • Points 755
    Re: deck problems
     I guess  have some problems with the mojo, maybe the firewire input are not working.
    When I tried HDV direct to my computer firewire , AVID will recgonize the deck
