Latest post Fri, Feb 6 2009 9:57 PM by Joachim Claus. 10 replies.
Page 1 of 1 (11 items)
  • Tue, Jul 29 2008 11:16 AM
    • curranpang
    • Joined on Sat, Jun 21 2008
    • Posts 4
    • Points 80
    no signal when capture from HDV
     i am using MC3.0 and sony HDV HDR-FX1E , i shot some HDV format footage from my HDV cam and i opened a project ( project type 1080i/50 , raster type HDV ) for capture . but it said "no signal present" ! i can control the HDV cam from my avid , and avid can read the timecode~ why?
    and i tried to shot some SD footage from the same cam , everything is fine .
    am i set something wrong in my HDV project?
    thank alot , and sorry for my poor english
  • Tue, Jul 29 2008 2:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Re: no signal when capture from HDV
     Sometimes those cameras have a menu setting to send a signal out via FW. Could that be the problem?
  • Tue, Jul 29 2008 11:28 PM In reply to
    • dennislink
    • Denver
    • Posts 348
    • Points 4,035
     If you change the downconvert setting in the camera, you need to physically disconnect the camera from the computer (and then reconnect it) in order for the computer to recognize the new setting.
    Core Duo 2.4 GHz 2GB RAM nVidia Quadro FX 550 [view my complete system specs]
  • Wed, Jul 30 2008 1:16 AM In reply to
    • Ken Larsen
    • Joined on Mon, Jul 28 2008
    • Minnesota, USA
    • Posts 14
    • Points 200
    I use a Sony HDR-HC1.  I was having similar problems.  I changed settings and it still wouldn't accept the signal.
    Finally I did set the camera to output HDV and turned off the HDV to DV conversion auto function.  It still didn't work.  So in desperation I shut off the camera and turned it back on.  Voila!! it worked.
    Ken
    PC, Intel quad core, 8 gigs ram, bunch of HD space. [view my complete system specs]
  • Fri, Aug 1 2008 5:33 AM In reply to
    • Mojave
    • Joined on Wed, Apr 30 2008
    • Posts 5
    • Points 65
    I have been having the same problem with HDV from a Canon XH-A1 using MC3 on a Vista system. Within a few seconds of starting the capture, I get the same, 'no signal present' message. I have spent hours trying to figure out what is going on. I have even tried uninstalling and reinstalling MC3.
    If anyone has any other idea, please share. I sure could use them!
  • Wed, Aug 6 2008 10:05 PM In reply to
    • CoPARQ
    • Joined on Wed, Mar 8 2006
    • Wisconsin
    • Posts 73
    • Points 905
    You could possible try defining a custom pre-roll of 10 sec+ (in the capture tool.) This has helped me.
    Newest System: Avid Nitris DX, HP xw8600, Intel Xeon X5450/3.00Ghz, WinXPSP3,Ciprico MediaVault U320, Quicktime v7.5.5, nVidia Quadro FX3700, 3.25 G RAM... [view my complete system specs]
    Colleen P.
  • Wed, Aug 6 2008 10:43 PM In reply to
    • ronn
    • San Diego
    • Posts 401
    • Points 4,910
    Try start>run - regsvr32 to fix your dvbuffers.ax
    also, make sure the camera/deck is not in downconvert mode and you're not trying to capture on the same bus segment as a Mojo.
    Media Composer 4.0.2, ASUS P6T/i7-920/12GB, Dell Studio XPS, i7-920/6GB, Windows Vista Ultimate 64 bit, HPxw8200 w/3GB/MC3.1.2/XP, FX1700, FX1300, FX570... [view my complete system specs]
    Ronn Kilby
    The Studio at Kilby Pond
    Valley Center, California
    www.kilbypond.com
    Where work - is a pleasure.
  • Thu, Feb 5 2009 1:37 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
      Moderator: Broadcast Newsroom
    mojave,
    Are you running Vista Business or Vista Ultimate?
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Thu, Feb 5 2009 6:57 PM In reply to
    • Mojave
    • Posts 5
    • Points 65
    I have been running Vista Ultimate.
  • Fri, Feb 6 2009 1:30 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
    MoJave,
    Vista business was tested and is supported.  Ultimate was not so I have no idea if this might be part of the issue.  I did ask QA to log this as a bug and they are workign to reproduce .....
    Can you try Vista business?
    813-493-6800 mobile
    AOL IM avidmarianna
  • Fri, Feb 6 2009 9:57 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 187
    • Points 2,265
    Marianna,
    I reported the same problem with Vista-64 Ultimate lats year, when MC 3.0 came out. You customer service has tried to solve it, but no success so far. The miracle is, that MC does not communicate with the cams/decks, while other software on the same system has no problem, e.g. Moviemaker or the Main Concept capture tool.
    In another thread http://community.avid.com/forums/t/67698.aspx?PageIndex=3    I reported about my experience with Windows 7 Beta 64-Ultimate. After initial proiblems with video palyback it now works fine - and captureing from my tape deck is also o.k.
    Joachim
    SuperMicro Workstation 7046A-3 Dual Xeon (Quadcore) X5550 2.67GHz 12 GB RAM PNY FX1700 Soundblaster Audigy 2 ZS Pro 4 SAS HDD's 300GB 15k (1 for OS... [view my complete system specs]
    Joachim Claus
