Latest post Wed, Aug 6 2008 10:43 PM by ronn. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Jul 29 2008 11:16 AM
    • curranpang
    • Joined on Sat, Jun 21 2008
    • Posts 4
    • Points 80
    no signal when capture from HDV
     i am using MC3.0 and sony HDV HDR-FX1E , i shot some HDV format footage from my HDV cam and i opened a project ( project type 1080i/50 , raster type HDV ) for capture . but it said "no signal present" ! i can control the HDV cam from my avid , and avid can read the timecode~ why?
    and i tried to shot some SD footage from the same cam , everything is fine .
    am i set something wrong in my HDV project?
    thank alot , and sorry for my poor english
  • Tue, Jul 29 2008 2:05 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,858
    • Points 175,640
    Re: no signal when capture from HDV
     Sometimes those cameras have a menu setting to send a signal out via FW. Could that be the problem?
  • Tue, Jul 29 2008 11:28 PM In reply to
    • dennislink
    • Denver
    • Posts 348
    • Points 4,035
     If you change the downconvert setting in the camera, you need to physically disconnect the camera from the computer (and then reconnect it) in order for the computer to recognize the new setting.
    Core Duo 2.4 GHz 2GB RAM nVidia Quadro FX 550 [view my complete system specs]
  • Wed, Jul 30 2008 1:16 AM In reply to
    • Ken Larsen
    • Joined on Mon, Jul 28 2008
    • Minnesota, USA
    • Posts 14
    • Points 200
    I use a Sony HDR-HC1.  I was having similar problems.  I changed settings and it still wouldn't accept the signal.
    Finally I did set the camera to output HDV and turned off the HDV to DV conversion auto function.  It still didn't work.  So in desperation I shut off the camera and turned it back on.  Voila!! it worked.
    Ken
    PC, Intel quad core, 8 gigs ram, bunch of HD space. [view my complete system specs]
  • Fri, Aug 1 2008 5:33 AM In reply to
    • Mojave
    • Joined on Wed, Apr 30 2008
    • Posts 3
    • Points 35
    I have been having the same problem with HDV from a Canon XH-A1 using MC3 on a Vista system. Within a few seconds of starting the capture, I get the same, 'no signal present' message. I have spent hours trying to figure out what is going on. I have even tried uninstalling and reinstalling MC3.
    If anyone has any other idea, please share. I sure could use them!
  • Wed, Aug 6 2008 10:05 PM In reply to
    • CoPARQ
    • Joined on Wed, Mar 8 2006
    • Wisconsin
    • Posts 63
    • Points 755
    You could possible try defining a custom pre-roll of 10 sec+ (in the capture tool.) This has helped me.
    System 1: Hp xw8200, XP Pro SP2, nVidia QuadroFX 1400, 3.5G RAM, Media Composer v.2.6.6. Toolkit v5.2.4 Ciprico MediaVault U320 Scsi, Quicktime 7.1... [view my complete system specs]
    Colleen P.
  • Wed, Aug 6 2008 10:43 PM In reply to
    • ronn
    • San Diego
    • Posts 303
    • Points 3,825
    Try start>run - regsvr32 to fix your dvbuffers.ax
    also, make sure the camera/deck is not in downconvert mode and you're not trying to capture on the same bus segment as a Mojo.
    Media Composer 3.x (3 seats), HPxw8200, 3GB RAM, Compaq Evo4000, 2GB RAM, HP xv5000, 2GB RAM, HP dv2500 (Core 2 Duo), Mojo Classic, Sony XDCam-EX1, Sony... [view my complete system specs]
    Ronn Kilby
    The Studio at Kilby Pond
    Valley Center, California
    www.kilbypond.com
    Where work - is a pleasure.
