Hi
I work with Xp Pro 5.5 and Boris Graffiti 4.0 for the titles and i have get to a point that if i try to make a title in Boris it work fine but when i try to render it in avid i get a pop up window that say:
API Error XIImageNative.cpp 733 "Not enough storage is available to process this command".
now as i can tell this error is not correct as i don't any problems of memory or of disk spacei have run a look on google and all i can find is that i an not the only one this happed to but there is no fix to this problem or and info way this happed
so for that i need your help as i must you Boris for my titles as this is the only tool that will give me the option to make titles in Hebrew as Avid will not support Hebrew font.
so do any of you seen this error and know how to fix it ?
update me
Yours
Tamir
so this error only happed to me ????
I think that it is related to your video card. What video card/drivers are you using?
I use the Nvdia FX 1400 with drivers ver 84.26
and the Avid Xpress pro ver 5.5
There were versions of Xpress Pro that produced this error. Maybe you could entertain the possibility of updating Xpress Pro.
