Latest post Fri, Aug 1 2008 1:20 PM by anomaly_7. 4 replies.
  • Fri, Jul 25 2008 4:38 PM
    • anomaly_7
    • Joined on Fri, May 12 2006
    • New York
    • Posts 73
    • Points 950
    MC 3.0 Crash on startup
    Hey All,
    I just recently installed MC3.0 on my 2.5GHz Intel Core 2 Duo MackBookPro, 4GB RAM. I am running Leopard 10.5.2. I went thru the whole install/restart thing and now when I start up AVID I get a Segmentation Fault error and then it force quits.
    Anyone, anyone?
    Thanks for all your help, whoever you may be,
    Sean
    2.5 Ghz Intel Core 2 Duo Macbook Pro, 4GB Ram. Mac OS X Leopard 10.5.3. [view my complete system specs]
  • Fri, Jul 25 2008 7:58 PM In reply to
    • anomaly_7
    • New York
    • Posts 73
    • Points 950
    Re: MC 3.0 Crash on startup
    If anyone knows where to point me to get the answer I need that would be great. I can't use AVID MC 3.0 until I get this figured out and I don't want to have to resort to using FCP 6.
    Thanks.
    Sean
  • Sat, Jul 26 2008 11:04 AM In reply to
    • Stephen Hawkins
    • Joined on Mon, Apr 21 2008
    • Clarence Valley, Ausralia
    • Posts 40
    • Points 450
    Hi anomaly_7, You indicated that you have Leopard 5.2 running MC 3.0, I think 10.5.3 is recommended for this version of Avid MC. Also you don't indicate the QT version which should be 7.4.5 as well.
    I would have a look a Avid specifications for Leopard and QT and make sure you are running the recommended versions first. Then if there is still a problem some of the forum users may be able to help.
    Don't forget to full out all your system specs. including any external hardware etc in your profile.
    Steve.
    iMac 2.4 4GB RAM OS10.5.4 QT7.5.5 MC3.05 CalDigit FW-VR Raid,Powerbook G4-867 1GB RAM OS10.4.11 QT741 XPro 583. [view my complete system specs]
  • Tue, Jul 29 2008 12:20 AM In reply to
    • anomaly_7
    • New York
    • Posts 73
    • Points 950
    OK, here goes...this is my problem.
    System Specs are as follows: 2.5 GHz Intel Core 2 Duo Macbook Pro, 4GB RAM. I am running Mac OS X Leopard 10.5.3. I recently upgraded to MC 3.0. Once installed, MC will not start up. It keeps giving me a segmentation fault error.
    What I did: Uninstall/Reinstall. Marianna was kind enough to give me an alternate installer from AVID's ftp site. I installed that. I tried calling Tech Support but they accidentally hung up on me and then when I tried to get thru it was after 7PM EST and everyone went home. I was told my dongle is good, so no need for a new versioner. I repaired my permissions.
    I have nothing connected to this CPU. No drives, flash memory, nothing. I don't know what else to say.
    Sean
  • Fri, Aug 1 2008 1:20 PM In reply to
    • anomaly_7
    • New York
    • Posts 73
    • Points 950
    So after several unsuccessful tries I contacted support and this is what they said: Hello Sean, It took a lot of time to research the problem and to talk with the engineers and these are the things that you need to try The thing is to try uninstalling the Caption plug-in: 1. control click on the AvidMediaComposer application 2. Choose Show Package Contents 3. Open the Contents > SharedSupport > AVX2_Plug-Ins folder 4. Drag Caption.avx out of the package 5. Launch AvidMediaComposer This should run without the segmentation fault... It seems that a poorly created font in the OS is conflicting with an AVX plugin. if this doesn't work: -Do you have a Mojo, Mojo SDI or Adrenaline attached to this system? Or any FW based drives or deck even? If so, there is a bug that can cause this error when using MC 3 and running OSX Leopard. Unhook any FW devices and see if the error continues. -This error WILL happen if you have not completely uninstalled EVERYTHING from an earlier version of the Avid software on this CPU. It can also happen if you uprade the OS to Leopard instead of doing a clean install. Could either of these be the case? If so, do an archive and install of the OS and then do a clean install of 3.0. Just use Carbon Copy Cloner to clone your drive over to an external FW drive, then, when you get Avid working, you can use the File Transfer Manager to restore your CPU's Users and applications very easily. Let me know if the problem is fixed. Greetings, Costin AVID Support Just thought I'd throw it out there in case anyone else experiences this. Sean
