Latest post Mon, Aug 11 2008 9:19 PM by prberg. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Jul 23 2008 5:46 PM
    • ublue
    • Joined on Thu, Jul 10 2008
    • Posts 16
    • Points 270
    Sorenson Squeeze
    Is sorenson squeeze compression suite version 4.3.302.4, compatible with avid media composer 2.8??
    And does it do BOTH flash and MPEG4 encoding for avid?
    If so, what are all the export settings I need to use in avid before compressing in squeeze?
  • Wed, Jul 23 2008 5:54 PM In reply to
    • camoscato
    • Posts 4,686
    • Points 55,860
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Sorenson Squeeze
    ublue:
    You don't have to do anything special.  Just export a Quicktime Reference movie from Media Composer, and open it up in Squeeze.
    As for the specific capability questions, someone else will have to chime in, because I'm not in front of a machine at the moment.
    good luck,
    Carl
  • Wed, Jul 23 2008 6:07 PM In reply to
    Export a QT Ref file. Use the Mastering settings in Avid's QT Ref window to ensure FX are rendered.
    Yes it can do both Flash and MPEG4.
    Tip: If you have a mixed media timeline (HDV, DV, 1:1, etc) you should do a video mixdown. QT and Squeeze don't behave well when dealing with QTRef files that have mixed formatas.
  • Thu, Jul 24 2008 4:51 PM In reply to
    • ublue
    • Posts 16
    • Points 270
     Thanks for the responses! But just so I'm absolutely sure...is s squeeze 4.3.302.4 compatible with avid media composer 2.8 (specifically)? thanks!
  • Thu, Jul 24 2008 5:14 PM In reply to
    There is no 'compatibility' factor per se because MC does not directly access Squeeze. And vice-versa. They interact via Quicktime files and codecs.
    Real answer is no answer. But in short, yes they work fine together assuming you have QT player installed and working.
  • Thu, Jul 24 2008 7:31 PM In reply to
    • macjaeger
    • Joined on Mon, Jun 16 2008
    • Coburg, Germany
    • Posts 200
    • Points 2,390
    Dom Q. Silverio:
    MC can't create QT reference files when HDV is involved (qt ref doesn't understand long gop formats). You'll always have to transcode the hdv material first or render your sequence to some intermediate format :-(
    MC 3.0 (soft) on 2.4Ghz Intel Core2Quad, 4GB, XP Pro, 2+1 Screens hooked to Nvidia GF7900GTO & Matrox DualHead2Go, 1 TB striping RAID [view my complete system specs]
    not a pro, just a teacher...
  • Thu, Jul 24 2008 8:19 PM In reply to
    You are correct. If QT supported HDV then MC would not have a problem with it as MC supports HDV natively.
  • Mon, Jul 28 2008 9:37 PM In reply to
    • ublue
    • Posts 16
    • Points 270
     so is sorenson squeeze or imo procoder better??
    is the procoder also compatible with avid mc 2.8?
    which one is cheaper (i don't need the latest version)...and where the heck do you buy this software!!!
    THANKS AGAIN FOR EVERYONE'S HELP!! I COULDN'T DO IT WITHOUT Y'ALL!
  • Mon, Jul 28 2008 9:41 PM In reply to
    Which is better depends on your needs. Squeeze is cheaper because it is free with your XPro/MC software (it is bundled with it).
    Where to buy it - all over the place. Just Google it.
  • Sun, Aug 10 2008 8:44 AM In reply to
    • prberg
    • Los Angeles, CA
    • Posts 197
    • Points 2,735
    Is this really still the case?  I have to do a video mixdown in order to get Squeeze to read my QT REF files?  I have a timeline with DV25 and 2:1 media.  When I export the QT REF and try to import it into Squeeze... Squeeze will quit out with an error message.  I have MC 3.0 and Squeeze 5.0.2.8.
    Can anyone help?
    thanks,
    -Peter B
    Asus P4C800-E Deluxe _ Pentium 4 3.2Ghz 2GB Ram_WinXP Pro SP3 Nvidia Quadro FX 1100 ATA100 7200rpm drives (1 for system, 1 for video) 2 SATA 7200rpm... [view my complete system specs]
  • Sun, Aug 10 2008 4:28 PM In reply to
    Have you tried the Safe Mode / GDI Only trick (search forum)?
    But yeah, there different characteristics of DV25 and 2:1 can cause problems for you.
  • Mon, Aug 11 2008 9:19 PM In reply to
    • prberg
    • Los Angeles, CA
    • Posts 197
    • Points 2,735
    Thanks for the tip, that solved the problem!  Wish they would put those kind of tips in the readme. (although I did find it in the knowledgebase after I got the tip from you).  thanks again.
    -Peter B
