Latest post Thu, Jul 24 2008 7:40 PM by macjaeger. 7 replies.
  • Wed, Jul 23 2008 4:39 PM
    • Spoonie Luv
    • Joined on Mon, Jul 24 2006
    • Washington, DC
    • Posts 117
    • Points 1,315
    render times and watermarks
    I have created a watermark with a psd from Photoshop and only got the oval shaped layer I needed using the matte key created by Media Composer.  The render time is about 4min for 1min of logo.  A Superimpose of a TIF is faster but doesn't give me just the shape that I need.  Is there a way to keep the oval and decrease the render time when this is put over 90 minutes of footage.
    I can render overnight so telling me the key is the way to go won't break my heart.
    any suggestions??
    well, i'm waiting. . . .     hehe
    hp workstation xw820 with windows XP SP2, intel xe [view my complete system specs]
    Tim Brumley, Combat Camera, Headquarters Marine Corps
    Filed under: , , ,
  • Wed, Jul 23 2008 4:43 PM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: render times and watermarks
    Hi Tim,
    Can you post a screenshot of what you're trying to do?  I'm having trouble picturing it.
    adios,
    Carl
  • Wed, Jul 23 2008 4:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,858
    • Points 175,640
    Tim, in photoshop, create your watermark as a single layer with no background layer. Then adjust the transparency to your likes and save the file as a .png.
    Now, when you import the file into AVid, make sure you invert the alpha in the import dialog box and it should come in perfectly as a RT matte Key.
  • Wed, Jul 23 2008 4:48 PM In reply to
    • Spoonie Luv
    • Washington, DC
    • Posts 117
    • Points 1,315
    A screen shot could take a while but the idea is to have my "company logo" in the bottom right corner at a 20% opacity like a watermark or the CBS eyeball on TV.
  • Wed, Jul 23 2008 4:51 PM In reply to
    • Spoonie Luv
    • Washington, DC
    • Posts 117
    • Points 1,315
    BLKDOG:
     I'm getting the matte key fine and the realtime is working but we export as a QT reference ( for DVD creation) and it renders everything before exporting.  The issue is pretty much time.
  • Wed, Jul 23 2008 4:56 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,858
    • Points 175,640
    Ok, so if the key is working, the render time should be a lot faster than what you are getting.
  • Wed, Jul 23 2008 5:16 PM In reply to
    • Spoonie Luv
    • Washington, DC
    • Posts 117
    • Points 1,315
     I started the render for the whole hour and you're right  the time has worked it's way down to less than a minute but it's still a 50 minute render for all tracks.  Better than having to wait overnight.
  • Thu, Jul 24 2008 7:40 PM In reply to
    • macjaeger
    • Joined on Mon, Jun 16 2008
    • Coburg, Germany
    • Posts 200
    • Points 2,390
    Spoonie Luv:
    QT reference is pretty much pointless when you have to render the whole clip anyway because each frame was changed due to the watermark. Basically you'll need at least the time it takes to uncompress each frame and compress it again, plus a little overhead for the overlay calculation. Sadly you can't export to mpeg2 directly, this silly limitation forces you to endure the double render (first on export to qt ref, then again in squeeze), uses two times diskspace, probably degrading your material. This is one sad example, where avids ignorance of mpeg2 complicates a workflow.
    MC 3.0 (soft) on 2.4Ghz Intel Core2Quad, 4GB, XP Pro, 2+1 Screens hooked to Nvidia GF7900GTO & Matrox DualHead2Go, 1 TB striping RAID [view my complete system specs]
    not a pro, just a teacher...
