Latest post Wed, Aug 6 2008 11:19 PM by MalachiX. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Jul 22 2008 11:55 PM
    • MalachiX
    • Joined on Thu, Jul 3 2008
    • Shreveport LA
    • Posts 56
    • Points 940
    Good encoding program with MC 3.0?
    I know the recommended one is Sorenson 5.0 but I've had so many issues with Sorenson in the past and I've heard mixed things about how well it works with multi-core processors.  I've got a rig with an Intel Core 2 Quad Q9450 CPU.  Can anyone recommend an encoder that will make good use of all the cores, gives me a lot of different formats to encode in, and has reliable performance?  Or has Sorenson improved drastically since Squeeze 4 (which is what I currently use)?
    MC 3.0 | Asus P5Q-E Mobo | Intel Core2Quad Q9450 | GeForce 9800GTX | 8 Gigs RAM | Windows Vista (64-bit) Business Edition | 1 TB Seagate HD [view my complete system specs]
  • Wed, Jul 23 2008 4:58 AM In reply to
    • Solopost
    • New Jersey
    • Posts 1,060
    • Points 12,070
    Re: Good encoding program with MC 3.0?
    I have used Sorenson since 4 and report no issues with it. I always give myself enough time for encoding in any project. If the client is looking for DVD deliverable - I allow, minimun of 48 hours on DVD encode, burn and test. Although it is much less after my initial DVD coaster design service days Big Smile. I just keep the 48 hours from the "Scotty" method.
    XW8200 2x3.2Ghz Xeon nVidia 3450 3Gb Ram Media Composer 3.0 w/Mojo 2Tb storage (mixed SCSI/SATA/1394)---------------Mac Pro 2xQuad-Core Intel 3Ghz 9Gb... [view my complete system specs]
    My Two Cents .02
    Kent Brockman
  • Wed, Jul 23 2008 6:28 AM In reply to
    • bastian
    • Joined on Fri, Jan 20 2006
    • Posts 11
    • Points 150
    TMPGEnc 4 Express is my do everthing encoder.  I love it - it just works!  I do use Sorrenson if I need to create flash files, otherwise it's TMPGEnc for everthything else from converting just about anything to Avid Quicktimes for import to creating just about anything from Avid Quicktimes.  It's reasonably priced and the lastest version update now supports MOD files, ACVHD etc.
    Even for non Avid stuff its great, eg I often use it when a client supplies a bunch of DVD's to re-author or compile to one DVD, TMPGEnc can demux the Vob files which then go straight into the DVD authoring program - no need for recompressing the video - 101 uses!!
  • Wed, Jul 23 2008 8:13 AM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,524
    • Points 18,340
    Sorenson for everything except mpeg2 has worked good for me. Squeez 5 has impressed qualitywise on me. Even the mpeg2 seams much better.
    Alternatives: Cinema Craft Basic for mpeg2 and Canopus Pro Coder for everything else.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05 [view my complete system specs]
  • Mon, Aug 4 2008 10:59 PM In reply to
     I use Autodesk Cleaner XL for some compressions, but I use Rhozet Carbon Coder for most of my critical work. It is pricey ($4,995), but it allows you to make H.264 quicktimes or .mp4 files (along with every other type of file )while being able to manipulate the gamma levels. I can set a gamma shift while outlining the black level range I want to modify (ex: from 10 to 192 on an 8-bit scale), so I can keep the blackest black levels but really open up the contrast ratio of a compression.
    5 x HP XW8400 Dual 3ghz dual-core. Adrenaline DnxHD hardware. Facilis Terrablock fiber storage. [view my complete system specs]
  • Tue, Aug 5 2008 1:01 AM In reply to
    • avidmedic
    • Joined on Mon, Jan 30 2006
    • Atlanta, ga
    • Posts 51
    • Points 555
    I have a client who swears by bitvice for Mpeg-2 encoding.  He is quite critical, and it passes his strict standards.
    BitVice
    You name it, I've seen it. [view my complete system specs]
  • Tue, Aug 5 2008 1:18 AM In reply to
    • Swil
    • Australia
    • Posts 424
    • Points 5,455
    bastian:
    I'm with Bastian. TMPGEnc rocks. And it's very cheap.
    Core 2 Quad Q6600 4Gb RAM 512Mb GeForce 9800 GT Media Composer 3.0 Windows Vista 64 [view my complete system specs]
  • Tue, Aug 5 2008 1:53 AM In reply to
    Squeeze is my standard encoder (QT, MPEG, Flash,etc).
    MediaCoder for everything else. It does MPEG 4/H.264 well. It can do burn in subtitling. Thus, perfect for my iTouch. It is well threaded. It is also free.
    http://mediacoder.sourceforge.net/
  • Tue, Aug 5 2008 12:13 PM In reply to
    • dor
    • Israel
    • Posts 212
    • Points 2,685
     Hi
    I saw at one palce there are using Carbon Coder.
    It is the same as ProCoder (same programmers I think) but Carbon Coder can use multi core CPU!
    MC 3.0.5 + MOJO SDI. Q9450+4GB RAM. 8800GT. XP PRO SP3 [view my complete system specs]
  • Tue, Aug 5 2008 1:09 PM In reply to
    • Adam Kranitz
    • Joined on Fri, Jun 13 2008
    • Avid Technology
    • Posts 44
    • Points 1,090
    MalachiX:
    I know the recommended one is Sorenson 5.0 but I've had so many issues with Sorenson in the past and I've heard mixed things about how well it works with multi-core processors....has Sorenson improved drastically since Squeeze 4 (which is what I currently use)?
    We have a video tutorial on the Expert Connections Blog about enabling Multi-Core Compression with Sorenson Squeeze 5. Let me know what you think.
    Media Composer 3.0.1, MacBook Pro 15", OS X 10.5.5 [view my complete system specs]
  • Wed, Aug 6 2008 10:09 PM In reply to
    • MalachiX
    • Shreveport LA
    • Posts 56
    • Points 940
    I'm giving TMP a try but all my files end up playing at a rather choppy framerate which doesn't make any sense given my specs (and the facts that other 720p files never slow down).  I'm not sure exactly what the problem is but it always looks as though there's something wrong with the FPS.  It doesn't chug or slow down, just looks jerky.  Could it be that TMP has a problem with 24 fps?
  • Wed, Aug 6 2008 11:19 PM In reply to
    • MalachiX
    • Shreveport LA
    • Posts 56
    • Points 940
    Ok, tried TMPGEnc again and now it seems to be working fine.  When I did my first batch, I set the FPS to 24 instead of 23.967 so that might have been what caused the animation to appear off.    Everything is easy to use and fairly powerful so it looks like I may stick with this sucker. I'm especially glad that it supports the higher end SSE4 processes of the new Intel Processors.
    One thing which I have found a bit odd though is my CPU usage.  I've got a Intel Core 2 Quad 9450 in there.  When encoding a Windows Media Player file, it looks to be making all four cores work as my CPU usage reads between 78-90%.  However, with Quicktime files and MPEG2's, it only ends up using about 35% of my total CPU power which tells me it's probably only using one core (yes I know that's technically 25% but apparently the Pyren processor's overclock one core when the other's aren't in use).
