Hi, all!
This problem started happening before an upgrade, and we were secretly hoping it would be fixed with the upgrade. Alas, we are not that fortunate.
Here's the issue- When I attempt to launch the AudioSuite tool to do a little compression magic, I am met with a crash.
The error I receive is: Bas System Call in Thread "Main Thread" at address 0xbffd300.
After I click whatever option there is on the first error message to dismiss it, I receive a second similar message before the option to close the application or report to Apple pops up. (This Mac is not on the internet, so a report is tougher to get in than under normal circumstances.) That second error reads: Illegal Instruction in thread "Main Thread" at address 0xbffd300
This happens while AudioSuite is loading. The status bar reads: Loading plug-ins:Avid_Application_Plugin %88
I'm a freelancer working on this client's Avid, so I'm not completely "at one" with the system. I wish I could offer more info on the recent upgrade, but I was not involved.
The system is currently running Media Composer v. 2.8.0 on a 2.7 GHz PowerMac G5. It's OS version is 10.4.8.
Any insight here, or is this a job for 1-800-800-Avid? I'm pretty sure there is a valid contract at this location. I just don't necessarily want to sit on the phone waiting to find out it's a mind-numbingly easy fix I could do....y'all know that feeling!!
thanks!
deb
This may be a Digidesign driver issue. Here's a link for downloading Digidesign drivers for Media Composer.
Thanks, Larry.
That link goes to a digidesign page that says: No information was found in this section for the product you selected.
I'll poke around a little bit between my logging duties today and see if anything looks promising.
If anyone else is familiar with this issue, please feel free to chime in!
Thanks!
Strange. That link was working two days ago. I'll poke around some more as well.
I'd suggest you uninstall Avid, clean any avid related files, reboot then re-install. The chances are this will resolve the problem.
So here are the steps:
AvidVDM.framework DAE.framework DigidesignFWDriver.framework DigidesignUSBDriver.framework DigiMachOServices.framwork DigiPlatformSupport.framework DigiPlugInHelper.framework DigiStreamManager.framework DigiStudioManager.framework lavaFlow.framework
I've had this problem in the past and this is how I resolved it. (Avid really needs to make their uninstallers do their job properly - which isn't the case at the moment)
Janusz
