Latest post Tue, Jul 22 2008 10:35 PM by Larry Rubin. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jul 22 2008 8:18 PM
    • JP Redman
    • Joined on Wed, May 31 2006
    • Sacramento, California
    • Posts 25
    • Points 465
    Getting Rid of Unused Renders
    My apologies If this question has been asked and answered, but I cannot find the thread.
    When one renders an effect or timeline a media file, which in-house we call a "render" is created. Correct?
    When one makes a change in the effect or timeline, you often must render again, which creates another "render" file. Correct?
    Now there are two "render" files. One being used and one no longer being used. Correct?
    Assuming this is so, your disk or workspace eventually ends up with a whole bunch of obsolete and un-used "renders" that are just taking up a lot of space.
    This is our experience.
    Is there a way to get Avid MC to automatically throw away obsolete "renders"?
    If not, is there a way to do it manually without incurring a bunch of risk?
    Feel free to correct any erroneous assumptions.
    Thanks.  JP
    Unity LANshare [v4.1] with ZX MediaArray (2TB)fiber networked to 2 - HP xw-8000 Adrenaline [both with Nvidia Quadro FX1100] (1 has DNxcel HD board)running... [view my complete system specs]
  • Tue, Jul 22 2008 8:34 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,190
    • Points 62,015
    Re: Getting Rid of Unused Renders
    Be careful deleting renders which are "pre-computes" in Avid lingo, because pre-computes not only include rendered effects, but also title clips and imported matte graphic files. If you throw away renders, they can always be re-rendered, no big woop. If you throw away title clips, they can easily be recreated using "recreate title media". But if you throw away imported graphic files, they will need to be imported from your original source files. The procedure is: highlight your sequence in it's bin and with all bins open, choose "show relatives" from the bin menu. Now open the media tool showing current project and pre-computes only, then choose "reverse selection". Those are the files that are currently super ceded and not used.
  • Tue, Jul 22 2008 8:37 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,717
    • Points 161,500
      Moderator: MCA Mac
    JP Redman:
    You are correct, though the file is called a "precompute".
    JP Redman:
    Sure, just open your media tool and tell it to display only precomputes for the current project. Now select your sequence and, from the BIN menu, choose "Select media relatives". This selects all of the precomputes that are being used in your cut. Now, from the same BIN menu, choose "Reverse Selection". This selects all of the precomputes that are NOT being use and you can now delete them.
    One caveat though. This process also deletes any Titles or RT Keys that may have been imported but not yet placed in the Timeline so, if you plan on using those later, you may want to hod off on the big delete or sift them out first.
  • Tue, Jul 22 2008 9:12 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 948
    • Points 11,510
    • Moderator: Avid Symphony Nitris
    This is taken from this beautiful old FAQ for Xpress DV, applies here as well.
    http://xdvfaq.tripod.com/#3.19
    3.19  Q. How do I delete unwanted Effects?
    A. Open Media Tool. Check all drives and current project. Check Precomputes and leave Master Clips and Media Files UNCHECKED. Click Ok,  a new window will open. Keep it open and visible. Open the bin with the sequence(s) and highlight them. In the hamburger menu (lower left corner of the bin window) select "Select Media Relatives". Any clips in the open bins, including the media tool bin that are used in the sequence will be highlighted. In the hamburger menu of the media tool bin select "Reverse Selection"  The precomputes that are not associated with that sequence are now highlighted. Hit delete and enjoy some more free space.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Tue, Jul 22 2008 9:22 PM In reply to
    • JP Redman
    • Posts 25
    • Points 465
    Thanks to all of you. Several people gave me the same procedure, so I'm good.
    I do have one more question tho' (I'm not an editor, I'm the Lan admin, so if the question is dumb, please bear with me) about the passage below.
    BLKDOG:
    I assume that if we put Titles, RT Keys and graphics in a different Bin from the one being purged, all will be fine. Correct?
    Thanks, JP
  • Tue, Jul 22 2008 9:28 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,717
    • Points 161,500
      Moderator: MCA Mac
    JP Redman:
    No JP as you will be deleting files from you HDs and not your bins. If you want to keep any precomputes, like titles, etc., after you "Reverse Selection", choose "Sift Selected" then highlight the Titles, etc, you want to keep in your bin and choose "Select Media Relatives" again from the BIN menu. Once the media is selected, click on the Media Tool and choose "Reverse Selection" again and then delete.
  • Tue, Jul 22 2008 10:03 PM In reply to
    • fiendish
    • Posts 205
    • Points 2,485
    Or you could simply 'Lock' all your graphic imports by highligting them in the bin and using the 'lock bin selection' command. I forget which menu it's in unfortunately.
    MC 3.0 / QT 7.4.5 on xw9400 with Mojo SDI - 4gb / quadro 3500 and 3ware 9650SE Raid 5 (and flamethrowers!) [view my complete system specs]
  • Tue, Jul 22 2008 10:12 PM In reply to
    • Scott Carnegie
    • Posts 948
    • Points 11,510
    That doesn't work with pre-computes, it will lock the master clip but still allow the pre-compute to be deleted.
  • Tue, Jul 22 2008 10:35 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,190
    • Points 62,015
    Scott Carnegie:
     Confirmed.
