I'm not sure if anyone else has mentioned this, but in 3.0 when you're fast-forwarding or rewinding footage at 150 or 240 FPS does it start to freeze, jump, stutter and otherwise not playback as fluidly as in 2.8? It happens on single streams and multi-cam footage exactly the same way. Anyone know why and most importantly how to fix it?
When I shuttle up to 60, 90 and 150 the speed functions fine with no stutter, going from 150 to 240 I do see a brief pause and stutter but only briefly and then the video resumes at that speed. For me this is not a problem however I did see some discussion in the past where this problem was discussed and there was mention of a fix in the works.
Also I didn’t catch your system specs, others trying to help you trouble shoot a problem might need those specs in order to help you out.
Hi
Read about it here
http://community.avid.com/forums/t/60119.aspx?PageIndex=2
I guess it is a bug
