Latest post Wed, Jul 23 2008 7:25 PM by EditGuy18. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jul 22 2008 11:57 AM
    • Vetalogy
    • Posts 106
    • Points 1,570
    HDV Hysteria
     greetings...
    I knew that I'm going to face some problems with HDV but not nightmares... I have MCA V2.7.2 with DNxHD IO Box, I have got HDV tapes shot on a JVC camera; DOP says it was shot 60HZ (camcoder: JVC GY-HD200). As I got the tapes, I tried to digitize the material using a JVC HDV player (JVC BR-HD50 set on 60HZ) but in vain. As I'm making a new project, I found out that I don't have 720P:60 format in the format choosing menu. I've got
    720P/23.976
    720p/29.97 HDV
    720P/50
    720P/59.94
    It seems that I got only one format that is supposed to be for HDV, as I tried the 720P/29.97 HDV format, and made the VTR configuration,started the digitize tool, remote control the VTR. As I activate the Video track, I got video on the record monitor (but it seems slow and sluggish) as I activate the audio track too I got a message indicating mismatch between what's expected and what's recieved. 1280/1280 720/720 30/60, it seems that there's incompatiable frame rate.
    I tried other 720P format but in the digitize tool, I got (No input signal message whenever I try to activate the video track), same applies even to other 1080i HDV formats (though I know it relates to Sony). I'm stuck there I don't know what's the problem, any help is highly appreciated. What format should I pick from Avid?
    Thanks a lot
    Dan
    N.B: JVC BR-HD50 Player is connected through its firewire port to a Pyro firewire card in the xw8200 station, The connection is firwire OHCI. T
  • Tue, Jul 22 2008 2:35 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 455
    • Points 5,595
    Re: HDV Hysteria
    The only JVC frame rate that is supported with that release is 720p/30 in a 720p/29.97 project. Media Composer 3.0 added support for the JVC GY-HD250U with support for the 720P-23.976/25/30/50/60 Hz.
    -- Bob Russo Applications Editor at Avid Technology
  • Tue, Jul 22 2008 4:16 PM In reply to
    • Vetalogy
    • Posts 106
    • Points 1,570
    Re: HDV Hysteria
     Thanks a lot BobRusso...
    Do you think there's anyway around this? And do you know if - technically- we can upgrade from V2.7.2 to v.3.0 with or without hardware changes?
  • Tue, Jul 22 2008 4:24 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 455
    • Points 5,595
    Re: HDV Hysteria
    The HP xw8200 and Windows XP are fully supported with MC3.0. But you should check the system requirements to make sure everything is correct.
    <http://www.avid.com/products/Media-Composer-Software/system-requirements.asp>
    If you go to the Avid store: <http://store.avid.com> you can purchase the update. There are two options, one for $295 for the Media Composer only and $395 for the Media Composer and third party software. The $395 option is a very good deal.
  • Tue, Jul 22 2008 4:55 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Re: HDV Hysteria
    BobRusso:
     ....When is Avid going to add capture and full editing support for the now longer line of Canon cameras that shoot at 24 F ? There are now five cameras in this line which are out there cranking away in 24 F and we're getting handed the tapes, yet Avid doesn't support this important HDV frame rate (1080 24 F) in the HDV 1440 x 1080 format.
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5, but had to roll back to 3.0.0. Also added Avid Studio Toolkit 5.7 running on.....HP... [view my complete system specs]
  • Wed, Jul 23 2008 7:25 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 149
    • Points 1,845
    Re: HDV Hysteria
     Vet,
    I use a Miranda HD-Bridge DEC+ with my HD-50 Deck.  It takes all flavors of JVC HDV in through the Firewire and spits it out 720P 59.94 through HD-SDI with either embeded audio or AES.  It works pretty slick.
    CR
    Avid Media Composer Adrenaline 2.8.1 HP XW8400 Workstation Twin Dual Core Xeon 2.66 Processors 3 Gig Ram Windows XP Pro SP 2 NVIDIA QuadroFX 1500... [view my complete system specs]
