Latest post Tue, Jul 29 2008 7:06 AM by abuditdit. 4 replies.
  • Tue, Jul 22 2008 7:43 AM
    • abuditdit
    • Joined on Mon, Jul 7 2008
    • Antipolo City, Philippines
    • Posts 12
    • Points 140
    Deleting Media Files in Unity Isis
    what is the proper way in deleting media files using the media manager...we are using the media manager for deleting files but we get error messages in some deleted files...
    Avid NewsCutter XP with Avid Mojo, HP xw8200 Intel Xeon 3.4Ghz, NVIDIA QUADRO FX 1400 128MB, 2GB RAM, on UNITY ISIS [view my complete system specs]
  • Tue, Jul 22 2008 5:39 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,127
    • Points 23,495
    Re: Deleting Media Files in Unity Isis
    What version of Media manager are you running,  and when was the MM server last restarted, or an IIS reset performed?
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
    Filed under: , ,
  • Thu, Jul 24 2008 2:23 AM In reply to
    • abuditdit
    • Posts 12
    • Points 140
    the version of the media manager is v.4.5.12...the last time it was restarted was 2 weeks ago...the error message is "unity connection error or path not found File://ssd/wncaa clips/avid media file/mxf/nc1.1/boxprem mai48c796c.mxf"...it depends on the clips that will be deleted and even when deleted it does not free up space in the drive....is it okay to delete disassociated file with the media manager?...(",)
  • Thu, Jul 24 2008 2:50 PM In reply to
    • Doc Avid
    • Posts 2,127
    • Points 23,495
    A few things.
    1. Your Media manager needs a kick in the Ram once in a while.   Open the command window on the server (this is when nobody is connected)   type in the following   iisreset  /restart      The service will stop..  then start again..
    2.  The system doesn't know your files are gone, most likely thrown away at the OS level.   Go to /ssd/wncaa clips/avid media file/mxf/nc1.1   on NC1.    Inside that folder you will find 1 media database,   Throw it away.     the system should rebuild that database at once, giving you a correct indication of what really is in that folder.   If it doesn't rebuild at once,  relaunch the editing application.
    3.  This process is repeatable on other media folders,  just be aware that a trashed database can only be rebuilt by the edit system that "owns" that folder name.
    JDS
    Filed under: ,
  • Tue, Jul 29 2008 7:06 AM In reply to
    • abuditdit
    • Posts 12
    • Points 140
    thank you very much...for the great help....deletion now is a breeze no errors reports....can i ask another question how can we delete media files that are now disassociated using the media manager...thank you....
