Latest post Wed, Apr 1 2009 11:13 PM by double-g. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Mon, Jul 21 2008 3:56 PM In reply to
    Re: MC3.0 Color Bugs
    Unfortunately I wasn't able to get a replacement pci-e or cable as its from my dealers existing setup - which i'm feeling stupid for not insisting on.
    I've installed OS10.5.2 on my second internal drive with a clean install of MC3.0 & QT7.4.5 with no luck there either.
    Matt
    MC3.5/Nitris DX/8 x 3.0GHz Harpertown/10GB Ram MC3.5/Mojo/Macbook Pro [view my complete system specs]
  • Tue, Jul 22 2008 12:31 AM In reply to
    You really need to test a new card and cable.  I'm not convinced it's the software.  The software works fine without the DX... so it's either the DX, the cable, the pci-e card or the pci- slot/bus IMHO.  You've ruled out the box by getting one that works on another setup.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Tue, Jul 22 2008 10:05 AM In reply to
    Do you have any peripherals attached to the DX box? Did you check for any video i/o or sdi signal loops? Is there a mismatch beween the video standards of any devices connected via sdi?
  • Mon, Aug 11 2008 4:43 AM In reply to
    Well it looks like the problem has been solved and strangely it turns out that the media is actually at fault. After much waiting for answers from Avid and none forthcoming (help is a little hard to find from Avid support on this side of the world) fortunately my dealers stepped in and solved it.
    To put it in context, originally my dailies were supplied to me in quicktime dnxhd codec and as I was cutting on a PC Adrenaline during this stage everything worked seamlessly. Relocating to another country once shoot completed, I purchased a new Mac Pro with Nitris DX and thats where the problems began.
    With the dealer being the only proactive one in terms of support we were able to ascertain that the problem appeared only on some clips and we tried playback on a multitude of Avid systems. Luckily experience has taught me to have many layers of backup and although all material is on HD SR, I took a backup of all the QT dailies with me before we left the shoot country. This allowed me to isolate the many problem clips and batch import them back into MC and the problem was solved.
    So with no help from Avid (apparently my case with Avid Singapore was upgraded to urgent although I never heard from them)  I can't confirm this but it seems to be an incompatibility between the dnx36 codec inside MC soft and the hardware codec on board the nitris. As one of my earlier posts showed, the problem clips were fine when I unplugged the DX and ran MC soft only. The errors only appeared when applying effects to the problem clips with DX attached.
    To isolate why some clips were not compatible with DX is the real mystery because all clips were digitized in the same system by the dailies company and played on the same two Avid Adrenalines before the DX migration.
    Sorry for the long post but I thought this info might be useful for others who may run across this problem. Moral of the story is always keep backups of the source files when working with file based delivery and never switch systems mid project (I couldn't avoid it as I was relocating countries).
    Thanks Todd, for your help with this. I can say that even with those problems, DX is a huge leap forward for Avid and is a joy to work on everyday - the novelty still hasn't worn off after a month on the new DX!
    Matt
  • Mon, Aug 11 2008 4:12 PM In reply to
    Matt,
    You are quite welcome.  I've passed along both your DX problem and your experience with Avid Singapore up the chain here in the states.
  • Thu, Aug 14 2008 9:40 PM In reply to
    • Posts 1,597
    • Points 19,905
      Avid Employee
      Moderator: Broadcast Newsroom
    Hello Matt,
    As Todd indicated, your situation was escalated to the head of Asia Pac support.  Jamie Ambrose has already been in touch regarding your post as I was copied on the email to you but I dont know if you have responded yet.  Jamie is heading up that effort for Avid now and he really wants to ensure that the Asia Pac team resolve any issues customers may have.
    You are in good hands.
    My apologies for any inconvenience you may have experienced.
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Wed, Apr 1 2009 12:13 AM In reply to
    • double-g
    • Joined on Thu, Feb 2 2006
    • Posts 13
    • Points 165
    Hi-
    Looks like we're suffering a very similar problem- the error we're getting (on playback of some DNX36 media) is exactly the same as what Matt was getting.  Likewise, the media plays fine when run in software-only mode.  We're using in-house tools that take TIFF's, and make AAF's, for delivery to editorial.  Marianna, do you know if there's a fix for this in the works?  Running in software-only isn't very viable, as today the problem cropped up as we were trying to lay off to HDCAMSR.  You can't really do that from an MCSoft..
    Thanks-
    Grant
    MC 3.0.5 Mac
    NitrisDX
  • Wed, Apr 1 2009 11:13 PM In reply to
    • double-g
    • Posts 13
    • Points 165
    You can disregard my previous post- it appears we were supplied with problematic TIFF's.
