Latest post Fri, Jul 18 2008 10:28 PM by robbidouglas. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Jul 18 2008 8:05 PM
    No Odd Even Field option in Quicktime Export
    I'm using Avid Xpress Pro HD 5.2.4 and Quicktime Pro 7.4.5, I'm trying to export to a quicktime movie file and in the Export Settings menu I don't get the box where I can choose between - Odd, Even or Single Field. In the Video Format box I get Width x Height, Color Levels and Pixel Aspect ratio, but no option for File Field Order which seems to be what everybody else has as an option. What's my problem?
    Avid Xpress Pro HD 5.2.4, Windows XP service pack 3, Intel Pentium 4 2.40ghz, 1GB RAM, Nvida GeForce FX5700. Canon XH-A1 HDV [view my complete system specs]
    Filed under: , , ,
  • Fri, Jul 18 2008 8:23 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 5,093
    • Points 60,860
    Re: No Odd Even Field option in Quicktime Export
     According to the version matrix, you should be running QT 7.0, not 7.4.5.
    Media Composer Adrenaline PC v 2.7.7 * Newscutter Adrenaline PC v 6.7.7 * XDCAM PDW-1500 & PDW1 * PDZ-1 XDCAM Browser * Pixelan SpiceMaster 2.0 plug... [view my complete system specs]
  • Fri, Jul 18 2008 9:07 PM In reply to
    Sounds less like of a Quicktime issue here (not that running 7.4.5 isn't an issue in of itself), but more like an issue with the project type being progressive. The options they've listed are the typical ones presented by Xpress Pro.
    If robbidouglas would kindly tell us the project type their working on first of all, that'd be really useful.
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Fri, Jul 18 2008 10:10 PM In reply to
    The project type is 25p PAL
  • Fri, Jul 18 2008 10:11 PM In reply to
    The project type is 25p PAL, will try the quicktime 7 see if that works.
  • Fri, Jul 18 2008 10:28 PM In reply to
    Ok, it's because the project is 25p, so I've changed it to 25i ... thanks for the help.
