Latest post Sun, Nov 16 2008 9:55 AM by luca.mg. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Jul 17 2008 5:15 PM
    • Ivo
    • Joined on Fri, Oct 21 2005
    • Germany
    • Posts 263
    • Points 3,475
    No audio hardware found on Vista 64 bit
    Avid can't find audio hardware on start up. I have Vista 64 bit. Audio is installed and working well with media player. Device manager is ok. No questionmark. What can I do?
    Avid Media Composer 4.0.2 Nitris DX Win Vista 64 bit SP1 2x Quad core 3,2 GHZ Nehalem 12 GB RAM NVidia Quadro FX 3800 14 TB storage S... [view my complete system specs]
  • Thu, Jul 17 2008 5:16 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Re: No audio hardware found on Vista 64 bit
    First, let us know what your Audio card is.
  • Thu, Jul 17 2008 5:19 PM In reply to
    • Ivo
    • Germany
    • Posts 263
    • Points 3,475
    Build in audio on supermicro X7DWA-N-O motherboard.
  • Thu, Jul 17 2008 5:45 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,838
    • Points 201,280
    Ok, I'm not expert on building a PC but I believe that is your problem. Avid requires very specific audio hardware.
    Hopefully someone more PC hardware savvy can jump in here and give you exact specs on what you need.
    In general, you need a soudblaster card and to disable the onboard audio (I think).
  • Fri, Jul 18 2008 1:08 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,242
    • Points 48,765
    I think that motherboard uses a Realtek sound chip.  It certainly uses HD 7.1 audio, and that may be your problem.  Try setting the sound to stereo rather than HD.  Avid doesn't play well with non-stereo configurations.
    If that doesn't work then Soundblaster will probably be your best bet.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Fri, Jul 18 2008 1:23 AM In reply to
    Also ... while crusing around the Microsoft Support Site, I saw an article, "No sound after Windows Update".  Hmmm ...
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Sun, Jul 20 2008 6:45 AM In reply to
    • Ivo
    • Germany
    • Posts 263
    • Points 3,475
    Yes it is a Realtek sound chip. I set the loudspeaker setup to stereo, but no change.
    Do anybody know a good soundcard which works with Visat 64bit and Avid?
  • Tue, Jul 22 2008 11:05 AM In reply to
    • jemand84
    • Joined on Tue, Jan 15 2008
    • Posts 12
    • Points 110
    Any M-Audio sound-hardware will do or a simple Creative Labs Soundcard.
    But I have to correct something ;) Avid does not need any specific sound hardware... Just just needs specific Hardware to be connected, but it does not have to be used.
    I can connect my M-Audio Fasttrack USB to my computer and still use the Realtek onboard sound with Avid. Funny, eh? Must be some *** contract between Creative and Avid. M-Audio "is" Avid, so that's serious ^^
  • Sat, Jul 26 2008 12:24 PM In reply to
    • Ivo
    • Germany
    • Posts 263
    • Points 3,475
    No I have E-MU 1212M PCI Soundcard and everythink works fine.
  • Tue, Jul 29 2008 10:35 AM In reply to
    • benfscott
    • Posts 4
    • Points 55
    HIya,
    I had the same problem with one machine using Realtek HD and no problem at all with a second machine.
    HOwever, I found a workaround on this site which was to
    1) disable sound card
    2) install the demo of Total recorder and enable the virtual sound card.
    3) open avid and in sound card configuration it should now read 'use windows mixer' if not select it.
    4) enable realtek audio and uninstall total recorder
    5) Restart Avid and now it works every time with Realtek sound.
    Worked like a charm from then on, so seems to be something in the Realtek software mixer rather than the audio chip itself. .
    Athlon 64 x2 6400, Foxconn C51 Mobo ATI 4850 512Mb 4Gb DDR 800mhz 500Gb Sata + 2 x USB 2. 250Gb drives. Avid MC 3.0 [view my complete system specs]
    'I preferred the old days of Atari STs and Commodore Amigas when you were positively encouraged to hit computers when they went wrong. '
  • Sat, Nov 15 2008 11:03 PM In reply to
    • mglasco
    • Joined on Thu, Oct 30 2008
    • Corning, NY
    • Posts 12
    • Points 150
    I also had a problem not finding my audio card. I found that my webcam conflicted with it. Avid doesn't like webcams or modems apparently, so disconnect them and restart your computer. That worked for me.
    Media Composer 3.1.2 - HP xw8600 - Vista Business 64bit - Intel Xeon 5440 2.83 - 8GB DDR2 - 1.5tb internal (2X 500 Gb raid 0 striped, plus 500GB) - 4 1394a... [view my complete system specs]
  • Sun, Nov 16 2008 9:55 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,409
    • Points 16,140
    Careful with M-Audio, some of their products do not have 64 bit drivers yet.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
