Latest post Thu, Jul 17 2008 6:44 PM by yale. 12 replies.
Page 1 of 1 (13 items)
  • Wed, Jul 16 2008 4:43 AM
    • mhamilton
    • Ottawa, Canada
    • Posts 494
    • Points 5,755
    capturing (mini-DV tapes): always stops at around 48-min. mark. Why?
    Hi there,
    I hope someone has a suggestion, because I've got a hundred of these tapes to capture - - I want to be able to hit Record at the top, and then just let it go, right to the end.  But Avid always stops recording somewhere after the 45-minute mark.
    I've checked all the settings I can think of (a few of you did say to get these settings figured out early on), with no luck.
    Any suggestions?
    Thanks, malcolm
    MBP 2.5GHz, 4GB RAM, OSX 10.5.4; Media Composer v.3 [view my complete system specs]
  • Wed, Jul 16 2008 9:46 AM In reply to
    • dor
    • Israel
    • Posts 201
    • Points 2,565
    Re: capturing (mini-DV tapes): always stops at around 48-min. mark. Why?
     Hi
    Do you capture to local disk or to a UNITY storage?
    In one places I used to work there was a bug in some version (that is similar to yours when capturing to a UNITY worksapce.
    I was solved I think only by software upgrade
    MC 3.0.5 + MOJO SDI. Q9450+4GB RAM. 8800GT. XP PRO SP3 [view my complete system specs]
  • Wed, Jul 16 2008 10:49 AM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,496
    • Points 17,930
    In project window:
    Settings/MXF Media Files
    Set Maximum (default) Capture time to e.g.120.
    Or, do you use DVCAM? There tapes stops at 48 min because DVCAM use 1.5 the tape speed as DV does.
    Dell 360, 3.2Mhz, 2 Gb RAM, Mojo. 80GB Sata bootdrive, 200GB SATA videodrive. Windows XP SP2, swedish version. MC 3.0 [view my complete system specs]
  • Wed, Jul 16 2008 4:48 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 494
    • Points 5,755
    Hi Dor and berga -
    capturing to SATA drives.
    ... they're just mini-DV tapes... I'll check the mxf media files settiing/capture time this aft.
    Thanks for the tips, Malcolm
  • Wed, Jul 16 2008 5:44 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 494
    • Points 5,755
    Just checked... MXF Media Files default capture time is set to 64 minutes, so I don't think it can be that.   Also in Capture Settings, 'Stop capture if a bad frame is detected' is unchecked, which I think is correct.
    I'll try the next tape.  I have 95 more to figure out the problem.
    Cheers, Malcolm
  • Wed, Jul 16 2008 7:21 PM In reply to
    • berga
    • Posts 1,496
    • Points 17,930
     Can You capture a second time from 48 min?
  • Thu, Jul 17 2008 2:59 AM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 494
    • Points 5,755
    Yes, but it means I have to take two passes for each tape... same thing happened again, by the way, at the 42-minute mark.
    Odd, eh?
    Malcolm
  • Thu, Jul 17 2008 8:20 AM In reply to
    • berga
    • Posts 1,496
    • Points 17,930
    In my experience, it is often difficult to capture DV-tapes. I can not remember one full DV-tape whcih I have capture without any problems. Babysitting is often a must. Small breaks in time code is there always. Do you know if the time code is continoues?
    Last time, I use capture across timecode breaks in Settings/Capture/General and Enable detection of small timecode breaks in Settings/Capture/DV&HDV Options and no scene extractions. Using crash record, setting the first frame in the vcr, no times in the caputre window and hit the read buttom and let it run. An it work, despite some small timecode breaks.
  • Thu, Jul 17 2008 11:21 AM In reply to
    • Stephen Hawkins
    • Joined on Mon, Apr 21 2008
    • Clarence Valley, Ausralia
    • Posts 40
    • Points 450
    Hi hamilton,
    These DV tapes wouldn't by any chance have been shot on a Canon XL1 series camera.
    Steve
    iMac 2.4 4GB RAM OS10.5.3 QT7.4.5 MC3 CalDigit FW-VR Raid,Powerbook G4-867 1GB RAM OS10.4.11 QT741 XPro 583. [view my complete system specs]
  • Thu, Jul 17 2008 2:31 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 494
    • Points 5,755
    Hi again,
    These tapes were shot with a few different mini-DV cameras I've had over the years, all Sony.
    Berga - - time code is continuous, from what I've seen (and I've specifically checked those places where Avid stops capturing, and the time code has been uninterrupted in each case).  It's something about the 40-something minute mark.  I think it might be that, the longer I'm capturing, the more 'lag' there is between playback in the camera, and capture into Avid... and at some point this lag actually stops things.  Does that sound possible?
    Anyway, if I have to baby-sit, I guess I have to baby-sit.  Thanks for your patience.
    Malcolm
  • Thu, Jul 17 2008 2:32 PM In reply to
    Batch it in 30 minute chunks... should work better.
    MC 3.0.5, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Thu, Jul 17 2008 3:32 PM In reply to
    • mhamilton
    • Ottawa, Canada
    • Posts 494
    • Points 5,755
    Yes that makes sense.  Then at least I'll always know where the break is.
    Thanks for the suggestion.  Malcolm
  • Thu, Jul 17 2008 6:44 PM In reply to
    • yale
    • Joined on Thu, May 15 2008
    • Fabulous HOLLYWOOD, CALIFORNIA!
    • Posts 81
    • Points 920
    If you're going over FireWire, this won't help, but if you're using an analog pathway to capture, it sometimes helps to run it through another device, such as a DVD recorder or VCR.  The device will stabilize the signal and essentially act as a time base corrector.  I've used this technique to capture really old VHS tapes that have degraded and have bad frames that cause Avid to choke, but if it's not stopping at the same point on each tape this probably isn't the issue.  Nevertheless, it might help with what you're trying to do--sometimes fluctuations in the signal can be the problem.
    Does it pop up an error message when it stops, or does it just stop and act like it completed the capture?
