Latest post Tue, Jul 15 2008 6:10 PM by briMestone. 4 replies.
  • Tue, Jul 15 2008 3:28 PM
    Basic Unity admin - when should I optimize and synchronize?
     I'm new to Unity and I'm on a new Unity too.  When should I optimize workspaces, and when should I synchronize workspaces?  My understanding is that it's best to always use protected/mirrored workspaces and that protected workspaces don't require optimization.  I have less crucial workspaces on my systems that contain example projects and practise media for new editors, etc that I'm running without protection.  My understanding is also that unprotected workspaces take up less space that protected ones, so when I'm pushed for space I'll take off the protection on less crucial workspaces to free up some GBs.  Is this approach correct or not?  Any comments and advice will be most welcome.
    Unity 5.0.1, 3x fibre connected XP clients (MC v3.0 and v2.7) see specs
    Avid Media Composer Adrenaline 3.0 HP xw8200 4GB RAM nVidia FX 1400 WinXP SP2 1 x 1.2TB Avid VideoRAID 5-drive config ****** Avid Media Composer... [view my complete system specs]
  • Tue, Jul 15 2008 5:16 PM In reply to
    • briMestone
    • Joined on Fri, Nov 18 2005
    • San Francisco
    • Posts 51
    • Points 575
    Re: Basic Unity admin - when should I optimize and synchronize?
    You need to optimized when you add new Drives into an Existing Allocation Group, this will cause the files to be broken down to muliple chucks and store across multiple drives within the Allocation Group.
    You Syncronize when you Enable "Mirroring" to an Existing Partition and vise versa. It basically syncronize the virtual backup partition of the specified partition.
    NOTE: its also a good idea to "Optimize" Partition from time to time, especially if you delete/add considerable amount of files.
    True that mirroring uses twice space compaired to "non-protected" but as the term says "Non-protected" is not appealling at all, (Drives are getting cheaper now), might wanna do the math, and not only that. Mirroring gives you more "Read" bandwidth.
    If a chuck of file needs to be access from a "Busy Drive", the Server is smart enough to locate the "Clone" chuck from the Mirror. thus giving you an extra power when you need it.
    2x Unity 5.1 with 7 MediaArray XT, 17 Adrenaline MC, 3 Mojo SDI, G5, xw8200, MAC Pro Quads, Protools [view my complete system specs]
    Ted Simbajon
    Head Janitor Wink
  • Tue, Jul 15 2008 5:55 PM In reply to
    briMestone:
    ....Mirroring gives you more "Read" bandwidth.
     It this documented anywhere?
    And how does one drive become more busy than another one in the same allocation group?
  • Tue, Jul 15 2008 6:01 PM In reply to
    CorneScheepers:
    When the difference in drive usage between the emptiest and the fullest drive exceeds 0.2%
  • Tue, Jul 15 2008 6:10 PM In reply to
    • briMestone
    • San Francisco
    • Posts 51
    • Points 575
    Theres a LOT of things thats totally un-documented.   Wink
    Ted Simbajon
    Head Janitor Wink
