Latest post Wed, Jul 23 2008 8:37 AM by camoscato. 202 replies.
Page 1 of 14 (203 items) 1 2 3 4 5 Next > ... Last »
  • Tue, Jul 15 2008 12:23 PM
    • silver101
    • Joined on Thu, Jun 14 2007
    • Auckland New Zealand
    • Posts 47
    • Points 585
    Oh Best Editor in the World, why oh Why can't you import Mpeg2 files?
    Locked Contact
    Oh dear Avid, you bought and ate Pinnacle Broadcast, have you digested the Mpeg 2 codec yet?
    We do motorsport. We use ChaseCam + flash drives + mpeg 2 for the incar cams, the same cams Formula 1, Super V8 etc use.
    We need to trans-code hours of mpeg2 files to AVI to be imported into Avid to be added to the edit.
    Avid creates HD m2v files, please we're at V3.0 (great upgrade), Any future plans for Mpeg2 support?
    We still need to revert to Avid Liquid (Swiss army knife) for conversion, to handle any format (I mean any format on the timeline even GOP's form DVD!!) MC can't.
    Any response or advise would be humbly received.
    HP xw8600 SDI mojo MC 3.0 [view my complete system specs]
  • Tue, Jul 15 2008 1:01 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 1,847
    • Points 24,595
    Re: Oh Best Editor in the World, why oh Why can't you import Mpeg2 files?
    Locked Contact
     Use a utility like the one that come with TmpGEnc Xpress 4 to convert your M2V and MPA into an HDV2 M2T (transport stream) and that will import directly into MC 3.0 without any loss of quality. MC 3.0 takes the M2T and converts it into MXF file(s).
    If you already have the files in Liquid, you can export MPEG-2 with the HDV 1080i preset which produces an MPG file. This has the M2V and MPA files already muxed but MC 3.0 can't read these. You can, however, drop this single MPG file into TmpGEnc and it will repackage it as a M2T file (which MC 3.0 will accept). I just tried this from Liquid -> MC 3.0 and it works.
    Camera(s) Sony HDR-FX1 \n System1: P5W-DH Deluxe Core 2 QUAD QX6700 (2.66GHz clocked to 3.17GHz), 4GB RAM (800MHz), 150Gb SATA-1 10000RPM Raptor system... [view my complete system specs]
    Steve
  • Tue, Jul 15 2008 2:58 PM In reply to
    • fiendish
    • Posts 233
    • Points 2,835
    Locked Contact
    still a workaround though. Why can't Avid import at least SD mpeg2 directly? While it's true that editing of GOP media is not ideal, MC already handles it for HDV and XDCAM.
    xw8600 Dual Quad 3ghz - MC 3.0.5 / QT 7.4.5 with Mojo SDI - 4gb RAM / Quadro 3700 and 3ware 9650SE Raid 5 [view my complete system specs]
  • Tue, Jul 15 2008 3:14 PM In reply to
    • Atomike
    • Nebraska
    • Posts 115
    • Points 1,750
    Locked Contact
    Agreed - my colleage uses a different brand of NLE, and it imports almost anything without breaking a sweat. I'm frankly embarassed that my NLE cannot. It makes my choice of machine look amateurish, which I find humiliating at times, especially since we paid alot more for my AVID than for his machine.
    Media Composer 2.8 with Mojo. Quicktime 7.3 2 Xeon 3.4 Ghz 800 FSB Processors. Quadro FX 1500 256 MB PCIe Video Card. 2 Gigs Registered ECC Memory. Xeon... [view my complete system specs]
  • Tue, Jul 15 2008 3:17 PM In reply to
    • evansmalley
    • Kansas City, MO (USA)
    • Posts 260
    • Points 3,265
    Locked Contact
    I totally agree... why do you have to use a completely extra app to do what many inferior apps (to MC) already do easily? It's like a fine LEXUS with only an AM radio...
    P4 XPsp2, 2.8 GHz, 2 gig RAM, 120 gig, 2x160 gig and 80 gig drives, much other external drive'n, dual-monitor mode, 2x MOTU 2408 mk2 ASIO, Tascam US... [view my complete system specs]
  • Tue, Jul 15 2008 3:42 PM In reply to
    • Sasquatch
    • Nottingham England
    • Posts 525
    • Points 6,300
    Locked Contact
     Agreed
    HPXW8400 4gb ram Nvidia FX 1500 MC 3 Adrenaline, HP XW8200 3gb ram Nvidia FX1400 MC 2.7 with SDI mojo, Avid express DV. [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Tue, Jul 15 2008 4:10 PM In reply to
    • Laptopeditor
    • Joined on Tue, Feb 27 2007
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Locked Contact
    Sasquatch:
     Agreed
     ...Agreed. MC should import anything.
    Upgraded to Media Composer from Avid Xpress Pro and now at MC 3.0.5, but had to roll back to 3.0.0. Also added Avid Studio Toolkit 5.7 running on.....HP... [view my complete system specs]
  • Tue, Jul 15 2008 4:11 PM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Locked Contact
    Sasquatch:
     Agreed
  • Tue, Jul 15 2008 4:12 PM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Locked Contact
     Why are there two identical posts of the same thing ? Huh?
  • Tue, Jul 15 2008 4:14 PM In reply to
    • SysMangler
    • Joined on Wed, Jun 18 2008
    • Oklahoma
    • Posts 36
    • Points 465
    Locked Contact
    I haven't tried this, and I won't be near my Avid system for a few days, but the QuickTime DVD plugin will allow QuickTime to read DVD (MPEG2) files.  Since that's the case, I wonder if you could open the MPEG2 sequence in QuickTime and then export a Quicktime Reference file pointing to the original MPEG2 and import into Avid?  If that worked, it would be quicker than any type of transcoding.
    MC3.0, XW4600, C2Q9650, 4GB DDR800, FX1700, 160G 7200 SATA (boot) + 2x300G 10K SATA (media), Pyro1394 PCI Express (API-316). Runs fine under XPPro/32,... [view my complete system specs]
  • Tue, Jul 15 2008 5:48 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 1,847
    • Points 24,595
    Locked Contact
     Agreed, however, repackaging the M2V and MPA in an M2T transport stream is not transcoding and will not suffer from generation loss.
    Each NLE has strengths. Evidently MC's strength is not in its file import flexibility.
    Steve
  • Tue, Jul 15 2008 8:56 PM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Locked Contact
    SysMangler:
    ....Huh ? There is a Quicktime DVD (MPEG 2) pluggin ? Where is this at ? Is this a pluggin inside MC 3.0 or is it located in the Quicktime Player itself ? Are you saying this allows you to directly import a DVD without having to use a third party application (Such as Cinematize 2 Pro) to extract the files to a QT codec, and then import into MC ?
  • Tue, Jul 15 2008 9:11 PM In reply to
    • SysMangler
    • Oklahoma
    • Posts 36
    • Points 465
    Locked Contact
    Laptopeditor:
    Try:  http://www.apple.com/quicktime/mpeg2/
    Have been using it since QT6 and has worked well for me.
  • Tue, Jul 15 2008 9:18 PM In reply to
    • silver101
    • Posts 47
    • Points 585
    Locked Contact
    So we're not alone, What does it help we can edit fast with great workflows and amazing desinged NLE's when we lose HOURS trans-coding media, money=time.
    If you want Avid to do something, let them know here so we canget a change, they do seem to listen.
    WE need mpeg 2 imports!!
  • Tue, Jul 15 2008 9:40 PM In reply to
    • Laptopeditor
    • Montreal, Canada
    • Posts 891
    • Points 11,095
    Locked Contact
    SysMangler:
    Laptopeditor:
     ...Thanks...I'll go check this out immediately.
