Latest post Thu, Jul 17 2008 12:06 AM by joelrmorgan. 12 replies.
Page 1 of 1 (13 items)
  • Tue, Jul 15 2008 12:00 PM
    • vamvax
    • Greece - UK
    • Posts 55
    • Points 755
    Standalone DVD recorder or DVD authoring software?
    Hello! I've made dozens of DVD, but I now have a client that is very demanding and wants a really high quality DVD. By doing a small research in the forums I see that most people recommend DVD authoring software instead of standaline dvd recorders to make high quality DVDs.
    I have used both, mostly Adobe Encore (by exporting QT ref or uncompressed QT from avid) and Pioneer standalone dvd recorders (via firewire directly from mojo or DV deck) and from my experience it seems that the standalone dvd recorders have much better results as far as image quality is concerned. The most common problem I have noticed in Adobe Encore is in dissolves which in most cases don't seem to be as smooth as they actually were.
    I'd really like to hear opinions on that as well as settings that people use to make high quality DVDs in dvd authoring software or recommendations on standalone DVD recorders. Just to note that my current project is a 25i one, shot on 16:9.Thanks!
    Yiannis
    Avid Xpress Pro HD 5.2.4 with Mojo [view my complete system specs]
  • Tue, Jul 15 2008 12:36 PM In reply to
    Re: Standalone DVD recorder or DVD authoring software?
    Hi Yiannis,
    I use both. I have a Sony Harddisk/DVD-recorder. I run an SDI line from my Avid to an AJA D10CE converter, which spits out RGBS. To get that into a European SCART input, you need a cable that not only connects the RGBS to the appropriate pins but you also have to feed it a DC current on a trigger input pin (I don't recall which exactly, and how much voltage).
    I've also used TMPEGEnc 2.5 to encode in software, it was recommended to me on the Avid-L years ago. I find it has an excellent encoder. It's not that good for creating menus and stuff (it's rather simple).
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Tue, Jul 15 2008 8:31 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,238
    • Points 36,795
     A hw recorder does a good job also when connected by firewire. Authoring with a recorder is almost impossible with most recorders. For a good encoder have a look at Cinemacreft encoder. Is is cheap and does a very good job. Also you could have a look at Sorenson Squeeze. Version 5 is ok. For authoring have a look at DVDlab Pro. Tons of options!
    Dell Precision 670Xeon 3Ghz 3GB Memory1 x 250 Gb S [view my complete system specs]
  • Tue, Jul 15 2008 9:22 PM In reply to
    jknikman:
    With DVDLab you can input the .vob files from a realtime DVD Recorder and it will demux them into usable files for all the authoring you cannot get with a realtime recorder.
  • Tue, Jul 15 2008 9:24 PM In reply to
    • jasperfdo
    • Joined on Wed, Oct 11 2006
    • Los Angeles
    • Posts 535
    • Points 6,935
    vamvax:
    i hear you man - every software/hardware encoder i see produces results that suck.  i want to see something that will burn a DVD the quality of a Warner Brothers movie...why would clients expect anything less?  they spend extra cash to shoot HD or RED and then they get a DVD isn't even up to standard def quality.
    I've even used like an $8K pioneer deck connected to a tape deck over SDI - so no signal degradation.  the results are horrible.
    Dell Precision 690, Intel 3.2GHz Dual Core Xeon (5060)4GB RAM, nVidia Quadro FX 3500 / Media Composer v3.0 / Mojo [view my complete system specs]
    kyler boudreau | www.theatereleven.com
    "Sometimes I wonder if men and women really suit each other. Perhaps they should live next door and just visit now and then. " - Katharine Hepburn
  • Tue, Jul 15 2008 9:54 PM In reply to
    jasperfdo:
    Have to disagree. HD to SD DVD via ProCoder 3 results in far superior to DVD's to those from Digi Beta edited 1:1
  • Wed, Jul 16 2008 6:35 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,238
    • Points 36,795
     yep, that makes hardware coding possible and authoring in DVD lab
  • Wed, Jul 16 2008 6:41 AM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,238
    • Points 36,795
    AndrewAction:
    jasperfdo:
     You certainly can get good results that way. You also might go the blue ray disk way.
    The quality you are hinting at is derived from very very expensive hardware encoding of small fragments of the original material. All these fragments are encoded with settings needed or that fragment to get the optimal result.
  • Wed, Jul 16 2008 2:48 PM In reply to
    • Susi
    • London, UK
    • Posts 163
    • Points 1,905
    Just bumped up against that today - a very beautiful short film brought to very nice DVD quality indeed via Sorenson and DVDlabPro; all save around 45" of very very fine and fast-moving detail that gives the game away. Seems that it would need very expensive high-end work to improve that 'fragment'.
    Just proves you can't have absolutely everything for tuppence, not that there aren't some fantastic options around. Very relieved to only need the DVD recorder option for editorial meetings now
    Avid Xpress Pro v5.6.4 (no Mojo) Windows XP Pro plus SP2 Intel(R) Xeon(TM) CPU 2 x 2.80GHz 2.00 GB RAM 80GB Seagate Barracuda U100 7200rpm (2MB Cache... [view my complete system specs]
  • Wed, Jul 16 2008 8:54 PM In reply to
    • jasperfdo
    • Los Angeles
    • Posts 535
    • Points 6,935
    AndrewAction:
    Hey Andrew - so Procoder 3 can be used to create a DVD that is the quality of any normal movie?  Cause if it will I'm totally buying it.  My DVD burning experience always result in stuff that just doesn't look as good as 'real' movies.
  • Wed, Jul 16 2008 9:08 PM In reply to
    jasperfdo:
    As a movie... probably not but there are alot of tweakables at the output stage. Better than a decently shot DigiBeta edited at full res and encoded to standard def DVD.. certainly.
    Obviously anything SD DVD is a little dissappointing after watching HDCAM all day on a decent screen. Stick out tongue
  • Wed, Jul 16 2008 9:33 PM In reply to
    • jdrouette
    • Vancouver, BC
    • Posts 70
    • Points 915
    It's also worth noting that most Hollywood feature DVDs are created from 24p/23.976 frame rate media, not 30i and therefore require less compression to fit onto a DL DVD-9.
    jd
    Avid Media Composer 3.0.5 + Avid Mojo DX on Mac OS 10.5.5, Mbox 2 Pro Tools LE 7.4.2. Mac Pro 2 x Dual Core Intel Xeon 2.66 Ghz 6GB SDRAM, NVIDIA GeForce... [view my complete system specs]
  • Thu, Jul 17 2008 12:06 AM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 131
    • Points 1,720
    vamvax:
    "....The most common problem I have noticed in Adobe Encore is in dissolves which in most cases don't seem to be as smooth as they actually were."
    I've noticed the same.  What's the deal?
    - Dell Precision 670 - Dual Xeon processors (2.8) - 2 gigs of Ram - nVidia 1400 (driver 7.7.1.8) - Creative SB X-Fi sound card - 120 Gig boot hard... [view my complete system specs]
