Latest post Tue, Jul 15 2008 3:14 PM by fiendish. 8 replies.
Page 1 of 1 (9 items)
  • Sun, Jul 13 2008 7:13 PM
    • Dignan
    • Posts 37
    • Points 405
    REDCine Fast Import DNxHD
    I'm an Avid editor in a largely FCP house.  We own a couple of RED One cameras and have been able to establish a pretty good workflow for our RED footage on the FCP side, but have an upcoming project that we need to cut on Avid, so I've been researching and tinkering a little, but haven't been able to come up with a workflow that meets our needs.
    Specific issue right now is - REDCine will let me export a DNxHD quicktime, but I can't seem to figure out how to make it create a file that will then fast import into the Avid.  Whenever I export a DNxHD quicktime out of REDCine, when I try to import into Avid, it is always a slow import - transcoding to make the file work.
    Anyone had any luck with getting REDCine to create a quicktime that will fast import into Avid?
    Thanks-
    D
    Avid Xpress Studio Complete Dell 670 [view my complete system specs]
  • Sun, Jul 13 2008 8:32 PM In reply to
    Re: REDCine Fast Import DNxHD
    I am tinkering too with the same issue and for the moment, I have a similar issue. It seems that only Bob at Avid knows how. I suggest you watch the video attached to the link below.
    http://www.studiodaily.com/main/video/9292.htm
  • Sun, Jul 13 2008 8:46 PM In reply to
    • GeorgeD
    • Posts 86
    • Points 1,015
     I have the same issue and resorted to exporting TIF16 and importing with DNxHD 10 bit. Slow but workable. I can import with Avid while Redcine is working in the background and still won't hit 100% processor usage. Havn't tried the new Red Rushes feature (on the Mac side) - that is next....
  • Sun, Jul 13 2008 8:48 PM In reply to
    • GeorgeD
    • Posts 86
    • Points 1,015
    Chris  - the link doesn't work.
  • Sun, Jul 13 2008 9:19 PM In reply to
    • Dignan
    • Posts 37
    • Points 405
    Thanks for the quick reply - have watched this video and done exactly as it instructs, but still can't seem to get a fast import compliant quicktime out of REDCine.
    http://www.studiodaily.com/main/video/9292.html is the link (I think you cut an "l"off.)
    Anyone?
  • Sun, Jul 13 2008 9:35 PM In reply to
    • timcappalli
    • Joined on Sun, Mar 30 2008
    • Rhode Island
    • Posts 7
    • Points 95
     check your color space settings (RGB/709)...I had issues with fast import of quicktimes until I tried the other color space...
    Tim
    HP Compaq 8710w Mobile Workstation Intel Core2Duo @ 2.40 4GB RAM Media Composer 3.0 Windows XP Professional SP2 and Windows Vista Ultimate... [view my complete system specs]
  • Sun, Jul 13 2008 9:39 PM In reply to
    • Dignan
    • Posts 37
    • Points 405
    Tim-
    So, you have been able to do a fast import of REDCine generated QT's successfully? I have tried both settings - RGB and 709.  I'd be eternally grateful if you could tell me exacty what settings you used to make it happen.
    Thanks-
    D
  • Sun, Jul 13 2008 9:57 PM In reply to
    • timcappalli
    • Rhode Island
    • Posts 7
    • Points 95
     I'm sorry, I should have clarified. I have done this with standard DNxHD...I could not get them to import successfully, but I was able to get it to work by changing the color settings. I have not done this with Red files.
    Sorry for the confusion.
  • Tue, Jul 15 2008 3:14 PM In reply to
    • fiendish
    • Posts 205
    • Points 2,485
    I succeeded in fast importing 25fps DNxHD from Redcine into MC 2.8 some time ago. From memory I think the fast import only worked when I was in a 1080 50i project rather than 25p, and make sure 709 colour space is selected. You will find much more help here
    http://www.reduser.net/forum/forumdisplay.php?f=19
    MC 3.0 / QT 7.4.5 on xw9400 with Mojo SDI - 4gb / quadro 3500 and 3ware 9650SE Raid 5 (and flamethrowers!) [view my complete system specs]
