Latest post Mon, Jul 14 2008 7:53 PM by bartoli. 3 replies.
  • Sat, Jul 12 2008 5:14 AM
    • bartoli
    • Posts 19
    • Points 195
    need help creating a stocks list!
    I am working on a show that has a massive amount of stocks where all the files have been imported as Quicktimes with unique names that identify them (like "istock000000234567") and was wondering if there was a way to get the AVID to create a list for me that I could print out?  Thios would make the ordering process much easier and I can avoid having to go through the sequence, cut by cut, to list them all manually.
    I was thinking about Decomposing the sequence, but am not sure if that is the right thing to do.
    Help as always will be appreicated.
  • Sat, Jul 12 2008 5:47 AM In reply to
    Re: need help creating a stocks list!
    If you're on v3.0, you can use the DumpSourceSummary command in the Console.
    http://community.avid.com/forums/141.aspx
  • Sat, Jul 12 2008 9:08 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 334
    • Points 4,025
    If you're not running v3, copy your sequence,then decompose selecting imported clips only (not captured), this will create a complete list of imported clips, including GFX and SFX etc...  But if you know all your clips start the same way, you can simply ignore them.
    There's another way using Set Bin Display, but the first way should work.
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Mon, Jul 14 2008 7:53 PM In reply to
    • bartoli
    • Posts 19
    • Points 195
    Thanks, I figured it was Decompose, but was not sure of there was some cool Composer function that I was unaware of.
    Barton
