Latest post Fri, Jul 11 2008 4:48 AM by MichaelP. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jul 10 2008 10:15 PM
    • KimK
    • Joined on Wed, Jun 25 2008
    • Posts 6
    • Points 70
    P2 24p 60i
    I am currently shooting interviews for a documentary in 1080/24p not 1080/24pa. I understand that the P2 material will only work in a 60i project unless you use something like MXFX to remove the pulldown. The client would like to have a delivered product 1080/24p.
    What are the pros and cons of editing in a 60i project and getting a 1080/24p when done vs. doing the pulldown and cutting in a 23.97p project. The documentary will likely have some older b-roll in it. Would it be better then to edit in a 60i project or transcode the b-roll to fit in the 23.97p project?
    Any pitfalls or benefits of doing it either way would help me avoid potential problems in the future.
    MC3.0, QT7.4.5, XP Pro SP3, Intel Core 2 Duo 6600 @ 2.4GHz, Asus P5W DH Deluxe Mobo, 2GB RAM, Quadro FX1300, System drive: 1 80GB Hitachi SATA, Media drive... [view my complete system specs]
  • Fri, Jul 11 2008 4:48 AM In reply to
    • MichaelP
    • Boston
    • Posts 1,486
    • Points 18,470
      Moderator: Film
    Re: P2 24p 60i
     Answer your second question with a question: "how much footage is going to be B-Roll and what percentage of that B-Roll was acquired interlace versus being a film to tape transfer?
    You can always take a 60i master with 2:3 pulldown in it and do what is called a "cadence align at the end of the process. While this works, the edit points which have broken cadence will have some artifcacts such as belended frames or 1/2 vertical resolution, etc.
    Depending on the percentage of B-Roll, you might consider nagtive 23.976 and convert B-Roll to 23,976 before capture. But that might get costly if there is a lot of footage.
    Michael
    HP 8600 Symphony Nitris DX v3 || MBP 15" Media Composer v3 [view my complete system specs]
    ____________ Anything 24fps
